So i ordered a brand new set of Polk MM6501 components, and i have a rockford T600-4... but i decided against rear fill for the moment. Is it possible to run my amp as a 2 channel on these mids? i realize 790rms is too much for 125 rms each side (250 total)
Will keeping the gains lower give me more headroom or something to this effect? Or should i just run it as a 4 channel (128 rms) and leave the other 2 channels empty for now till i find a better use.
I do have a dd1, i was thinking setting the gains on SQ setting as a 2 channel on my 600-4... maybe that wouldnt be too much as long as i have a clean signal from the HU and a clean signal super low gain on my amp?....
Help please. Installing on tuesday
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
You run 2 woofers and 2 tweeters off a 4 channel that can easily push double the speakers RMS?
Id just hate to pop 200$ of speakers on the first day.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Dial the amp down to run rms power. Mids and highs will burn up really fast once they start to stink
Ohms law: power = v2/r where v is ac voltage, and r is the resistance
No i will have 2 woofers and 2 tweeters total. 1 600-4 total. 128 x 4 @ 4 ohms or 395 x 2 @ 4 ohms (on birth sheet)
My question is... is it beneficial to run my amp as a 2 channel (395 rms) but keep the gain super low (confirmed zero distortion with my DD1) or just run them on 2 of my 4 channels (128 rms)
They will take a single channel of my amp full power no problem. But i was unsure of "headroom" and its principles. That maybe theres a benefit to giving the speakers way too much power but keeping the gains so they are not putting out Max RMS power (set using my DD1)
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
If this is true... then 14.4 squared is 207.36... 207.36 / 2.7 (actual resistance of my speakers at hand) is 76.8 RMS.. and since they can take 125 rms then i can run 2 channels on one set?
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Where are you getting 14.4 from?
125w=v2/2.7ohms
125*2.7=v2
337.5=v2
v=18.4v
So now hook up your dd-1 and a vol meter to the output on your amp, play 1kHz -5db and adjust your gain so your amp puts out 18.4vac, making sure that the dd-1 doesn't indicate distortion.
I would be careful clamping your amp in 2 channel with your mids hooked up. Unless you start with your gains all the way down and burp for like 1 second, which makes it really hard to get an accurate reading. I bridged my 4-channel ran it to my components, voltage without any speakers hooked up was 34v. Hooked up speakers to see what i got under load, and in the time it took to get a god reading i cooked my mids. Was doing 120-130 watts a 1khz to 90w rms speakers. I should have just left well enough alone because on music they were doing fine, probably seing around 100-110 watts. And i had everything set with the 0db tone using the dd-1.
You may not have the same problem but then again, you want to risk it?
125w=v2/2.7ohms
125*2.7=v2
337.5=v2
v=18.4v
Yeah that was noob, i was thinking 14.4 volts lol. time to google some to help me understand the valuable info you just provided in a language i dont fully understand =]
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
