Box for 1 Zv3 18...look right?
BEEMDUB
Vertical slot box has three common walls, not two, and the horizontal slot box has 1 common wall, not 2. That will change the net and tuning slightly. Also, your port area should be between 12-16 or 14-16 depending on who you ask. One box has way too little port area, the other has way too much.
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
neither will end up being that effecient, your first one has way too much port area, and is too small for the 18, your second is fine for internal space, but has way too little port area
try for around 4.5-5.5 cubes with 15-17" of port per cube
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
The boxes aren't even comparable, 3.6 cubes vs 5.93 cubes?
Yea I knew there was a big difference in size and port obviously ...I couldn't find any specs on the damn sub so I just designed it to his max dims...Torres is acting weird though like it won't even calculate a 5 inch wide port, not matter how long I try to make it it wont go below like 39..
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
