I'm looking to make another enclosure for my Type- R's.
I currently Have 2- 10" Alpine Type-Rs in a sealed box. Approx .7ft3 per sub.
I'm running these subs on a Hifonics BRZ2400.1d wired in 1-ohm configuration.
Looking to put them in a ported box. This will be going in a 2011 Aveo hatchback.
I'm thinking subs up, port up. I'm looking at 3.53ft3.
Dimensions of the box will be:
27W*18H*16L
2- 3" round ports 5.5"L
Tuning freq comes to 35.67Hz
port disp .05ft3
net vol 3.48ft3
gross vol 3.53ft3
port area range 31-45in2
port area- 7.07 in2
port area per ft- 2.03in2
This will be about the best configuration for me, as I will not have to move the amplifier. I currently have the sealed box and amp mounted on a sheet of mdf in the hatch now. I can roll the seats forward and access the spare tire easily with the current setup, and wish to maintain that ability with these subs.
Please double check my math, and let me know if this setup is worth building, or if I should leave the setup in the box it's in.
2011 Chevrolet Aveo(click for build log)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
Knukonceptz 1/0 Kollosus Fleks Cable
8 AWG Sky High Car Audio OFC
1/0- Sky High Car Audio
2- XP3000 XS Power Batteries
SMD VM-1
2- 12" Ascendant Audio Mayhems
Toolmaker Fuse block
Toolmaker Bus Bars
(Last Season scores 1-15" Mayhem)
145.2 dB- Sealed @ NSPL World Finals (9/28/14)
148.1 dB- Hardcore @ NSPL World Finals (9/27/14)
150.23-- Hardcore on 4500 Watts!!!!
New Build (2015, 2-12" Mayhems)
146.9- Sealed on dash
149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
Your port area is off and your net volume high, for your vehicle I would suggest the following if you can fit the small increase in external dimensions:
Enclosure Specifications:
Fb = 35 Hz
Vb = 2.24 ft^3
External Height = 17 in
External Width = 26 in
External Depth = 15 in
Port Width = 2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Top & Bottom = 26 x 15
Left & Right Sides = 13 1/2 x 15 1/2
2x Front = 12 x 15 1/2
Back = 26 x 15 1/2
Shared Port Internal Assembly Parts:
2 x Front to Back = 12 1/2 x 15 1/2
2 x Extension = 9 1/4 x 15 1/2
Let me know any questions.
Edited by Joe X
you're going to put 600 watt rated TENS getting twice their rated power in a 3 cubic foot box? Maybe if these were DD's or AQ's but certainly not alpines.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
old r's 600w, new r's 1000w. but yeah your right these are alpines and you might want to be careful lol
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
Sorry, these are swr-1042d type-r's.
2-500 rms
1500 peak.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
2-500 rms
1500 peak.
Changed the above for 2 x SWR-1042D, hope you understand the kind of amp power you are dealing with, set the subsonic filter to 30-31 Hz.
Edited by Joe X
2-500 rms
1500 peak.
Changed the above for 2 x SWR-1242D, hope you understand the kind of amp power you are dealing with, set the subsonic filter to 30-31 Hz.
This is why I don't like your "designs". Your attention to detail is lacking significantly. If I hadn't caught that, it would've gone unnoticed.
More box builds
It's a brz series, the claimed wattage is rated at 14.4V.
He won't be playing music @ 14.4V, not to mention box rise.
New Setup;
H/U; Pioneer DEH-80prs.
Wiring; 2 runs of 2/0 OFC & Big 3.
Subs; 2 D1 DC Level 4s.
Monoblock; DC 3.5k.
4 Channel; JBL GTO1004.
Highs; Vifa NE25VTS-04.
Mids; Aura NS6-255-8A.
Alt; 160a.
Batts; Optima, KHC1800.
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
