45s without table saw??
alpine always suggest to never use 45s, they decrease the score, but can help in some cases.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
45's actually take away the DB's was either Alpine or skittlergood that did testing on it. Can't remember which.
Probably because the 45s most people use take up extra cuft. Instead of getting tight triangular shaped wedges that fit perfectly in the corner.
New Setup;
H/U; Pioneer DEH-80prs.
Wiring; 2 runs of 2/0 OFC & Big 3.
Subs; 2 D1 DC Level 4s.
Monoblock; DC 3.5k.
4 Channel; JBL GTO1004.
Highs; Vifa NE25VTS-04.
Mids; Aura NS6-255-8A.
Alt; 160a.
Batts; Optima, KHC1800.
so what does that do besides take up space as well? Your logic isnt exactly going to help your argument.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
It does take up space, but not nearly as much.
Example below.
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
I like the precut from the hardware store idea, if you have to use a circular saw you can easily enough cut one side of the 45 with a fence from a larger sheet of wood. Cut the piece long enough to do all you 45's. Then cut the other side. Easier than working with small pieces
Example below.
so again whats your argument. you made the statement back it up.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I dont know why yall want to argue about 45s taking up airspace. If you plan on using 45s in the box, then allow for that airspace that the 45s will take up. Simple solution. Of course if you test the same box with and without 45s, there will be a difference. Build 2 boxes with the same exact airspace, one with 45s and one without. That will be your test to see if they help or not.
ill put how ever much money on NOT.. its an easy bet i will win 99% of the time
  • Who's Online   0 Members, 0 Anonymous, 1084 Guests (See full list)
