Upgrade suggestions?
budah93
Here is a suggestion subs up/port back 2x sa-15 1.6k RMS amp:
Enclosure Specifications:
Fb = 35 Hz
Vb = 8 ft^3
External Height = 22.5 in
External Width = 37 in
External Depth = 26 in
Port Width = 31 in
Port Height = 3 5/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 37 x 26
Left & Right Sides = 24 1/2 x 20 1/4
Front & Back = 37 x 20 1/4
L Port Internal Assembly Parts:
Front to Back = 19 1/4 x 32 1/2
Port Left Side Assembly:
19 1/4 x 3 5/8
Port Right Side Assembly:
19 1/4 x 3 5/8
Assembly guide (generic dimensions):
A single brace of the two shown will be more than enough. Let me know any questions.
vertical vs horizontal doesn't change much just stay away from areo or round ports they have really bad port noise
Build in progress
Alpine CDEHD-138BT
Alpine SPX-17PRO 2x
Alpine SWS-15d2 2x
Alpine PDX-V9 2x
Alpine PDX-M12
Stinger SPC5050
Stinger 1/0ga and 4ga
Audioquest interconnects and Speaker wire
Dynomat 10455 mega bulk pak
Dynomat 1/8 and 1/4 liner
All that in a Reg cab truck and it wont be a blow though
I've heard that having a horizontal port can cause port noise so i think i would want mine vertical
What you have heard is untrue but I tried for the vertical port and it can be done but it's so tight that your cuts would need to be exact:
Fb = 35.3 Hz
Vb = 8 ft^3
External Height = 22 in
External Depth = 27 in
Port Width = 5 5/8 in
Cut Sheet List:
2 x Top & Bottom (3 parts) = 37 x 27
Left & Right Sides = 25 1/2 x 19 3/4
2x Front = 15 11/16 x 19 3/4
Back = 37 x 19 3/4
Shared Port Internal Assembly Parts:
2 x Front to Back = 17 1/2 x 19 3/4
This is very incorrect,
Whoever told you this or designed your box, is very uneducated, in the world of box design
Aeros can not be used in every box, but in thoes that they can they work very well
Side note, have you ever seen a high end home audio setup with slot port, or do they all use aero?
Then ask yourself why?
i dont do home audio so no. Second i heard that on the SSA Forum when I was designing a box for my other car. But if i'm not going to have port noise i'll gladly try a horizontal
  • Who's Online   0 Members, 0 Anonymous, 1379 Guests (See full list)
