how big of a difference does a 4v output hu and a 2v output hu make?
C-Fizzy, on 01 April 2012 - 01:06 PM, said:
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
Check out my build thread http://www.stevemead...product-page-2/
New build
http://www.stevemeadedesigns.com/board/topic/172646-punkrocks-97-civic-build/
the stronger the signal is getting to your amps, which means less gain will equal louder, but doesnt mean you can turn your gain up more, its meant for you to be able to match your amp gain to the preout level
hope that makes sense, it kinda doesnt to me
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
About twice the preamp output voltage
No
No
no? how so?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
You should research and read more before posting.
Higher output voltage is suppose to help cut down on noise in the line. Theoretically any noise electrical or otherwise that isn't in the source signal will be a lower percentage od the total signal at higher voltage. Thus giving you a cleaner signal. If you don't have any issue with noise in your system a higher voltage probably won't help.
to me there is a big difference,
not 100%, but to my knowledge, the higher the voltage the cleaner the signal can be made,
my eclipse system was 5v and sounded very clean and off the dd1 didn't clip until 72 out of 80 on 0db
But output voltage won't effect what volume the head unit clips at, my clarion is 2v and won't clip even at max volume.
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
