Skar set up
Boarhog35
Hey anyone here run Skar vvx 10s? If so how loud do they get? I am running 2 vvx 10's in a
Ported box tuned to 32hz and I doesn't get
Loud. It has a Skar 1500 watt amp and I am using a new clarion cz702 radio. Any pointers or wires that I should check? What should the amp setting be set to? They are wired at 1 ohm. I am thinking a bad wire because I have heard that skars play clean and loud.
You have 2 10's. On 1500 watts.
You expecting to hit 50's cuz they say skar across the front?
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Ok in the first post you said why isn't it loud. Sooooo what are you looking for.
under construction
u hate c-fizzy?
I am trying to figure out if I missed something while installing the subs. You know alot when
It comes to subs and Wiring and thought that you could help. I didn't know if there was a common problem with sub wiring that would affect
The subs.
Do you have a digital multimeter? If you do, unplug the wires going into the amp. They should read 1 ohm.
If you wired the subs wrong at all those wires won't read 1 ohm.
under construction
u hate c-fizzy?
Okay thanks I'll try it
  • Who's Online   1 Member, 0 Anonymous, 649 Guests (See full list)
