copper or brass, if you can find it. but it wont make much difference what you use.
OK, i just didn't know if there were some weird bolts that wouldn't conduct a signal or not. and how do i set it up? like what bolts, washers and nuts to use, and how to arrange them?
Posted (edited)
I don't use any special anything. Just regular bolts, washers and nuts.
Bolt --> Terminal --> Washer --> Wood --> Washer --> Terminal --> Nut
Hope that helps.
Edited by kl0wn
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
Posted (edited)
itll look like this
bolt, ring terminal, washer, box, washer, nut, washer, ring terminal, washer, nut.
edit, use two nuts so you dont have to reach inside the box if you ever want to change wiring or something.
Edited by skittlesRgood
i should have done this instead of running the wires through a couple holes i drilled
C-Fizzy, on 01 April 2012 - 01:06 PM, said:
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
Check out my build thread http://www.stevemead...product-page-2/
New build
http://www.stevemeadedesigns.com/board/topic/172646-punkrocks-97-civic-build/
i use the biggest bolts that will fit the ring terminals i'm using. i put the ring terminal on between two washers, then bolt them on. on the outside i sometimes use wing nuts so it can be removed if need be and no tools are present
i like the wing nut idea, because it is a family truck, so the box has to be taken out sometimes. is there any way i should go about making sure they're sealed?
arrange them in whatever way gives u a constant connection to metal. i use just 2 washers and a nut
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
  • Who's Online   0 Members, 0 Anonymous, 649 Guests (See full list)
