Dman1320 Posted August 25, 2012 Report Share Posted August 25, 2012 quick question. what bolts do i use to make the wire terminals on a box like in this pic? wasnt sure what type of hardware to use. Quote Link to comment Share on other sites More sharing options...
skittlesRgood Posted August 25, 2012 Report Share Posted August 25, 2012 copper or brass, if you can find it. but it wont make much difference what you use. Quote If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people. Link to comment Share on other sites More sharing options...
Dman1320 Posted August 25, 2012 Author Report Share Posted August 25, 2012 OK, i just didn't know if there were some weird bolts that wouldn't conduct a signal or not. and how do i set it up? like what bolts, washers and nuts to use, and how to arrange them? Quote Link to comment Share on other sites More sharing options...
kl0wn Posted August 25, 2012 Report Share Posted August 25, 2012 (edited) I don't use any special anything. Just regular bolts, washers and nuts. Bolt --> Terminal --> Washer --> Wood --> Washer --> Terminal --> Nut Hope that helps. Edited August 25, 2012 by kl0wn Quote 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz Link to comment Share on other sites More sharing options...
skittlesRgood Posted August 25, 2012 Report Share Posted August 25, 2012 (edited) itll look like this bolt, ring terminal, washer, box, washer, nut, washer, ring terminal, washer, nut. edit, use two nuts so you dont have to reach inside the box if you ever want to change wiring or something. Edited August 25, 2012 by skittlesRgood Quote If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people. Link to comment Share on other sites More sharing options...
punkrockprs Posted August 25, 2012 Report Share Posted August 25, 2012 i should have done this instead of running the wires through a couple holes i drilled Quote C-Fizzy, on 01 April 2012 - 01:06 PM, said: Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch. Check out my build thread http://www.stevemead...product-page-2/ New build http://www.stevemeadedesigns.com/board/topic/172646-punkrocks-97-civic-build/ Link to comment Share on other sites More sharing options...
Torres Posted August 25, 2012 Report Share Posted August 25, 2012 i use the biggest bolts that will fit the ring terminals i'm using. i put the ring terminal on between two washers, then bolt them on. on the outside i sometimes use wing nuts so it can be removed if need be and no tools are present Quote Link to comment Share on other sites More sharing options...
Dman1320 Posted August 25, 2012 Author Report Share Posted August 25, 2012 i like the wing nut idea, because it is a family truck, so the box has to be taken out sometimes. is there any way i should go about making sure they're sealed? Quote Link to comment Share on other sites More sharing options...
412 CVX Posted August 25, 2012 Report Share Posted August 25, 2012 click the second link down in my sig! Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
TylerParrish Posted August 25, 2012 Report Share Posted August 25, 2012 arrange them in whatever way gives u a constant connection to metal. i use just 2 washers and a nut Quote What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter Link to comment Share on other sites More sharing options...
