how to make terminal on box with bolts?
copper or brass, if you can find it. but it wont make much difference what you use.
I don't use any special anything. Just regular bolts, washers and nuts.
Bolt --> Terminal --> Washer --> Wood --> Washer --> Terminal --> Nut
Hope that helps.
Edited by kl0wn
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
itll look like this
bolt, ring terminal, washer, box, washer, nut, washer, ring terminal, washer, nut.
edit, use two nuts so you dont have to reach inside the box if you ever want to change wiring or something.
Edited by skittlesRgood
i should have done this instead of running the wires through a couple holes i drilled
C-Fizzy, on 01 April 2012 - 01:06 PM, said:
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
Check out my build thread http://www.stevemead...product-page-2/
New build
http://www.stevemeadedesigns.com/board/topic/172646-punkrocks-97-civic-build/
i use the biggest bolts that will fit the ring terminals i'm using. i put the ring terminal on between two washers, then bolt them on. on the outside i sometimes use wing nuts so it can be removed if need be and no tools are present
arrange them in whatever way gives u a constant connection to metal. i use just 2 washers and a nut
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
  • Who's Online   0 Members, 0 Anonymous, 948 Guests (See full list)
