06 Tahoe-Crossfire 8k/4 15" XS v2's! Triple alts in!
Thanks for the replies guys!
Yea the paint roller I got says it's for walls I believe. For the port I might pick up a can of gloss black to keep it smooth.
As for the port area, I wanted to keep it right at 12" of port per cube because this is more of a proven design. It helps keep port velocity high which is my goal. Trust me my first instinct was a port with 16-18" of port per cube, but after some research I am going to try this first. I can always make it bigger down the road.
Hoping to knock out the rest of the bracing today, and maybe begin painting :)
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Cutting holes for all-thread, flush mounted port side holes.
Internal bracing, dual nuts, lock nut, washer, and some loctite
Baffles officially on
Getting closer to paint!
Package just showed up, 4 more runs of 0g, 50ft of 8g for subs, and 100ft of 16g for future speakers!
Bracing from top to bottom complete! If this thing isn't rock solid then idk what is lol
Might add a couple wood braces to the sides if I'm feelin froggy tomorrow. What y'all think?
Good job with the bracing man. Looks good and everything looks evenly spaced also. I like how they are recessed into the box. An Audio Technix box is always a good sign. Those Crossfire subs really look beastly though
- 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene
My Selling Feedback
Build Log
Thanks bro, got them as even as I could. I thought the recessed would look good plus I had to do it on the bottom so that it would sit flush on the floor.
Let's just hope they don't pull through, the back and bottom are the only panels that would since it's only 3/4 thick and I went in 1/2". My buddy did his like this and it held fine. We'll see soon :)
Port in and framed in
First layer of bedliner on
The port will be sprayed gloss black so it stays smooth. Let me know what you guys think!
Second coat on
Looking good so far. I'm building the same body style Tahoe right now.
If that port is too small it will be super easy to make a larger one the way you have it set up. Tuned in.
8 SSA EVIL 15's
4 CRESCENDO 5500'S
2 SINGER HAIRPIN'S
21 XS POWER D1600'S
ALL MCLAREN AUDIO MID'S AND TWEETERS
1 TARAMPS HD4000, 1 TARAMPS HD800
SEX!
  • Who's Online   0 Members, 0 Anonymous, 1461 Guests (See full list)
