ToNasty Posted August 27, 2012 Report Posted August 27, 2012 I have been reading and reading. People say to hook the gauge into the battery. Some say hook it up.into the amp. Well im running 2 amps through a distro block. Is it possible.to hook it up into the block? If so which side? Thanks ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
n8ball2013 Posted August 27, 2012 Report Posted August 27, 2012 you can get the 12volt reading anywhere there is 12volt in and you want to know what your voltage is at that point THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
ToNasty Posted August 27, 2012 Author Report Posted August 27, 2012 So i can hook it into the distroblock then ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
n8ball2013 Posted August 27, 2012 Report Posted August 27, 2012 yes THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
ToNasty Posted August 27, 2012 Author Report Posted August 27, 2012 Would that be the best spot or what would.you recommend ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Tebo Posted August 27, 2012 Report Posted August 27, 2012 Either way if there is voltage drop in the system you will see it. 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
KillaCam Posted August 27, 2012 Report Posted August 27, 2012 Would that be the best spot or what would.you recommend Hook it up wherever you want to read the voltage, the amp would be the best seeing as that's what you're monitoring. Are they both mono block amps? At the rear battery or distro block would be fine though. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
ToNasty Posted August 27, 2012 Author Report Posted August 27, 2012 Im running a mono and a 4ch. I think im going ti run it to the input of the distro block until i get a rear battery ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
KillaCam Posted August 27, 2012 Report Posted August 27, 2012 That would be fine but I would run it to the mono amp. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
ToNasty Posted August 27, 2012 Author Report Posted August 27, 2012 Just because it the one drawing more power? ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
