soundstream15 Posted August 28, 2012 Report Posted August 28, 2012 It's a hatchback right? If so then that is why..your set up is better tho, alpine type rs are good subs. Do you have the big 3? If not you should do that, could help:)
ZachG Posted August 28, 2012 Author Report Posted August 28, 2012 well..... You both have: Different cars Different Amps Different boxes Wired to Different Ohms And more than likely....Different wires..... The Type R isn't a terrible sub, they can get pretty loud in the right set up (Which goes for alot of drivers) The best way to really see whos is louder would be to use one of the two set ups and test both pairs of drivers in the same box, same car, etc Then put it on a mic (If you can find one) I would guess that the amount of cabin space is what sets you two apart the most. But that is just my opinion... I have much better wire and my voltage is probaly better cause I have a big agm as a second batt Sweet. Any deadener in trunk?? Got some 80mil from knu on the trunk lid and my wing still flexes crazy on most songs. Like I measured it moves up 3/4 a inch on rack city haha 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
ZachG Posted August 28, 2012 Author Report Posted August 28, 2012 It's a hatchback right? If so then that is why..your set up is better tho, alpine type rs are good subs. Do you have the big 3? If not you should do that, could help:) I have yet to do that. On my car it seems very difficult so I don't know when I will do it & yes it is 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
michigancapri92 Posted August 28, 2012 Report Posted August 28, 2012 And you are really judging performance by distance you can hear the song? No I'm not judging performance. I believe if I was tuned higher around 36hz you could hear it from farther away. Come to think of it my box is actually tuned around 31.5hz It kills the lows down to around 29-30hz but isn't loud from outside why do you need loud outside the car ??? i bet yours is louder from the inside and sound better ..... most people who have those cars you hear from far away are cheap prefab boxes that sound like crap Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
ZachG Posted August 28, 2012 Author Report Posted August 28, 2012 And you are really judging performance by distance you can hear the song? No I'm not judging performance. I believe if I was tuned higher around 36hz you could hear it from farther away. Come to think of it my box is actually tuned around 31.5hz It kills the lows down to around 29-30hz but isn't loud from outside why do you need loud outside the car ??? i bet yours is louder from the inside and sound better ..... most people who have those cars you hear from far away are cheap prefab boxes that sound like crap Well trying to sound good and be loud from outside is a goal of mine, obv inside I want it to be loud and clear. I have yet to get on the meter cause I don't think I'm broken in yet..surrounds are still a little stiff. But I don't think I'd do good being tuned so low. & if its not raining tommrow I'm going to take out everything and flip the box Foward frieing and seal it off to see if I can hear a difference. I'm going to use plastic before foam so I can just take it out if I don't like it 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
LT.Smoke Posted August 28, 2012 Report Posted August 28, 2012 And you are really judging performance by distance you can hear the song? No I'm not judging performance. I believe if I was tuned higher around 36hz you could hear it from farther away. Come to think of it my box is actually tuned around 31.5hz It kills the lows down to around 29-30hz but isn't loud from outside I just want to say this... Dont worry about being louder OUTSIDE the car than inside... If it sounds good inside man then fuck the outside... You REALLY dont want to disturb others around you if you can help it that leads to the bad rep we get man Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
ZachG Posted August 28, 2012 Author Report Posted August 28, 2012 And you are really judging performance by distance you can hear the song? No I'm not judging performance. I believe if I was tuned higher around 36hz you could hear it from farther away. Come to think of it my box is actually tuned around 31.5hz It kills the lows down to around 29-30hz but isn't loud from outside And you are really judging performance by distance you can hear the song? No I'm not judging performance. I believe if I was tuned higher around 36hz you could hear it from farther away. Come to think of it my box is actually tuned around 31.5hz It kills the lows down to around 29-30hz but isn't loud from outside I just want to say this... Dont worry about being louder OUTSIDE the car than inside... If it sounds good inside man then fuck the outside... You REALLY dont want to disturb others around you if you can help it that leads to the bad rep we get man Well yea Im not that guy that bumps near public places, unless its at traffic lights ext to all the city people that come out by me haha. & my rear bumper and trunk rattle bad and flex bad. Not sure how to stop the bumper other than sealing off from the trunk 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Omega5002 Posted August 28, 2012 Report Posted August 28, 2012 Plus the only true way to see if your friend is louder or not is the termlab. Though personally, if you're louder inside the car, that's more impressive to me. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
michigancapri92 Posted August 28, 2012 Report Posted August 28, 2012 And you are really judging performance by distance you can hear the song? No I'm not judging performance. I believe if I was tuned higher around 36hz you could hear it from farther away. Come to think of it my box is actually tuned around 31.5hz It kills the lows down to around 29-30hz but isn't loud from outside why do you need loud outside the car ??? i bet yours is louder from the inside and sound better ..... most people who have those cars you hear from far away are cheap prefab boxes that sound like crap Well trying to sound good and be loud from outside is a goal of mine, obv inside I want it to be loud and clear. I have yet to get on the meter cause I don't think I'm broken in yet..surrounds are still a little stiff. But I don't think I'd do good being tuned so low. & if its not raining tommrow I'm going to take out everything and flip the box Foward frieing and seal it off to see if I can hear a difference. I'm going to use plastic before foam so I can just take it out if I don't like it in my oppinion i think having a goal of being loud from the outside is what gives us a bad rep .... your surrounds should never get softer .... if they are getting softer that is not a good thing ... when the subs get more and more broken in its the spiders that will get softer not the surrounds Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
GimicCarAudio Posted August 28, 2012 Report Posted August 28, 2012 well..... You both have: Different cars Different Amps Different boxes Wired to Different Ohms And more than likely....Different wires..... The Type R isn't a terrible sub, they can get pretty loud in the right set up (Which goes for alot of drivers) The best way to really see whos is louder would be to use one of the two set ups and test both pairs of drivers in the same box, same car, etc Then put it on a mic (If you can find one) I would guess that the amount of cabin space is what sets you two apart the most. But that is just my opinion... I have much better wire and my voltage is probaly better cause I have a big agm as a second batt so? his box is different. his woofers are different. his car is different. there are a TON of factors that you dont even know about. Bahahahahaha Thank you capt. Obvious Sorry I didn't join this SMD band wagon sooner, Guess a few more posts would gain me some respect?? I appologize for not having said knowledge. Since YOU have enough knowledge to tell me what I do and do not know why don't YOU type the novel that would describe every other factor. Didn't want to put so much time in a post, Just give him the obvious factors to understand why they may sound so different. Thank you again almighty car audio wizard for getting butthurt and THINKING you know more than someone for the number of posts they make on a website.... Everything is just a GIMIC 2004 Chevrolet Trailblazer Alpine CDA-9885 Rockford Fosgate Power t600.4 Pioneer 3-ways Skar 1500.1 (2) Skar vvx 12"
