liftedz71withbass Posted August 28, 2012 Report Posted August 28, 2012 I'm Planning to run like 4k by Christmas and still with a little bit of budget xs and all the big name battiers for car audio are out of question Im looking at the c&d 134ah what opinions do yall have to give on them? Good? Whats oldest build date I should get? Are they still around a lot I see a lot of old post selling them not a lot of new. Even the 100ah are they worth getting? Opinions on the sprint 370s? Just looking for decent batteries on a decently small budget 05 trailblazer Sub-3 Aq hdc3 18 with psi recones (need motors hmu) Sub amps- 2 Lanzar opti 3200 153.1
liftedz71withbass Posted August 29, 2012 Author Report Posted August 29, 2012 Bump, not a single person run these? 05 trailblazer Sub-3 Aq hdc3 18 with psi recones (need motors hmu) Sub amps- 2 Lanzar opti 3200 153.1
aleroking Posted August 29, 2012 Report Posted August 29, 2012 i run 5 of the 97 ah c&d batteries i got for 60 each ( 30 for battery, 30 for core charge. ) they hold voltage better on a 100 amp load test about .5- 1 volt higher depending on battery than my old kinetik 2400s iirc there like 130-140 ah. There great for if your on a budget. 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
Lbox88 Posted August 29, 2012 Report Posted August 29, 2012 Cheapest budget batts I've found would be oreillys Superstart AGM, which is a rebranded Deka. UBL | Build Log
liftedz71withbass Posted August 29, 2012 Author Report Posted August 29, 2012 i run 5 of the 97 ah c&d batteries i got for 60 each ( 30 for battery, 30 for core charge. ) they hold voltage better on a 100 amp load test about .5- 1 volt higher depending on battery than my old kinetik 2400s iirc there like 130-140 ah. There great for if your on a budget. .Where you get yours from? 05 trailblazer Sub-3 Aq hdc3 18 with psi recones (need motors hmu) Sub amps- 2 Lanzar opti 3200 153.1
aleroking Posted August 29, 2012 Report Posted August 29, 2012 i run 5 of the 97 ah c&d batteries i got for 60 each ( 30 for battery, 30 for core charge. ) they hold voltage better on a 100 amp load test about .5- 1 volt higher depending on battery than my old kinetik 2400s iirc there like 130-140 ah. There great for if your on a budget. .Where you get yours from? square deal in tampa florida. 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
ChevyBoy95 Posted August 29, 2012 Report Posted August 29, 2012 i have 2 of the 147ah and a 78ah, i run about 4500-5000rms daily, can fulltilt at idle and not drop below 13.7v with a 200a alt. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
liftedz71withbass Posted August 29, 2012 Author Report Posted August 29, 2012 Sounds good so really looking in to them.. If anybody else has anymore opinions please post them 05 trailblazer Sub-3 Aq hdc3 18 with psi recones (need motors hmu) Sub amps- 2 Lanzar opti 3200 153.1
liftedz71withbass Posted September 1, 2012 Author Report Posted September 1, 2012 Bump. 05 trailblazer Sub-3 Aq hdc3 18 with psi recones (need motors hmu) Sub amps- 2 Lanzar opti 3200 153.1
Jordan Guess Posted September 1, 2012 Report Posted September 1, 2012 i as well am on a budget for batteries, input in this post would be nice.
