7.3L diesel issue, advice needed
Unlikely, because the computer is gonna pick that up and correct for it. Most likely your egr is leaking coolant into the intake, or you have blown headgaskets, bad injector(s), your injector driver control module is bad. Or a combo of more than one of these. If I remember correctly the IDCM on the 7.3's is pretty cheap.
Unless your unemployed, your time is valuable, a $50-$100 tow bill, and a $100 to hook your truck up at ford is still cost effective, just saying. Good luck though!
Hey, I'm sure you're aware of this, but I'll put it out there in case you don't know. Diesel file systems are HIGHLY pressurized. Please be careful if you're fucking around with the fuel lines or injectors. Ive seen guys slice themselves when taking a fuel line off from the pressurized FIRE hose powered stream of fuel. Just my .02. I believe you have an injector issue as well, for what it's worth.
7.3 don't have a common rail fuel system like most other diesel motors . The fuel pressure after the pressure pump on top of the motor should be around 68lbs . The oil in the motor is the same oil that runs the high pressure oil pump that runs the injectors. 7.3s don't have a egr cooler like the 6.0 .
get it to operating temp, then see what it does. most diesels will smoke a little when cold. also ckeck the air cleaner, make sure its not plugged. the cam sensor is also known to go out on the powerstrokes.
Guessing he forgot to update this. It turned out to be water in the fuel being the whole damn problem.
Simple basic thing to look for that was over looked.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
I just saw this, and was about to ask about the water in fuel lol.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
