DylanBunch Posted September 2, 2012 Report Posted September 2, 2012 Would 2 kicker L7 15s over power aftermarket speakers on a stock 4 channel amp? 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
412 CVX Posted September 2, 2012 Report Posted September 2, 2012 One way to find out. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Omega5002 Posted September 2, 2012 Report Posted September 2, 2012 Test it and find out, if it overpowers your mid's and high's, buy a 4 channel, simple as that. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
DylanBunch Posted September 2, 2012 Author Report Posted September 2, 2012 true, but with my headunit, i cant install an aftermarket headunit because of lack of rca plugs 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
satish1015 Posted September 2, 2012 Report Posted September 2, 2012 i had a 10 inch l7 that overpowered my stock mids off my headunit.. then i added a 4 channel and it was good... so best way is to try it and see! i have a 4 channel kenwood that i may want to let go of soon 2008 BMW 550i M Sport Build coming soon! 2000 Volvo s40 1.9TPioneer DVD navigation head unitO2 audio performance mid range speakers2 Crescendo PWX-6 Pro Mid Range Speakers2 Crescendo PWX-8 Pro Mid Range Speakers4 Selenium ST200 Super TweetersHifonics ZRX2000.4 Amplifier2- 12 inch DC Audio Level 4 m2Hifonics Brutus BXI-1610D Amplifier2 KinetiK HC1400R- Secondary BatteriesKinetik HC600- Secondary BatteryKnukonceptz 1/0 gauge big 3 upgrade
412 CVX Posted September 2, 2012 Report Posted September 2, 2012 If you're able to install a sub amp, then you can install a second one. get a couple RCA Y-splitters Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
DylanBunch Posted September 2, 2012 Author Report Posted September 2, 2012 If you're able to install a sub amp, then you can install a second one. get a couple RCA Y-splitters so even though i only have 1 red and 1 white rca plug left, i can still hook up a 4 channel with those y splitters? 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
HunterJohnson Posted September 2, 2012 Report Posted September 2, 2012 Yup y split them. The signal is the same to the 4ch and bass amp. The amp will process the sound and filter it Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
DylanBunch Posted September 2, 2012 Author Report Posted September 2, 2012 awesome 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
DylanBunch Posted September 2, 2012 Author Report Posted September 2, 2012 now the question is, do i get one with 1 male 2 female or 2 male 1 female 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
