Hey bud just to let you know Singer and I believe Mechman make those Hairpin Alts. Singer quoted me a 250a before when I was interested in buying one of these.
Also, like said before do a nice DSP and do 3 way active! That's what I planned on doing with one of these mofo's.
Mechman said they don't make an alt for this yet, would have to send very very detailed pictures and measurements and/or send the alt in for a unit, as for singer, I'll never touch one of his units lol, as for running 3 way active that is my plan, not right away though most likely come spring time or so
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
small update today, well actually took me quite some time to get such little done, ended up popping a couple random fuses somehow, had to re-wire it a couple times thinking my wiring was fucking shit up, just happened i had my 12v+ tapped and had a kink in the wire grounding out on the vehicle, stupid small mistake that got me worried lol but alls fixed now
started wiring up the LC2i and Clarion EQ. I was hoping the EQ fit in the center console, so close but doesnt, EQ is about 1/4" too wide. also had difficulty finding a spot for the LC2i where i could get easy access to it when needed. I decided to throw both in my glove box. Until now i never realized how small the glovebox was, or even how oddly shaped it is, so nothing fits right lol
ALSO disovered my factory HU has a set of preamp outputs lol, sub only though, so i decided to go with the LC2i anyway cause i will eventually have a 4 channel being wired up, so i took the signal from my rear speakers (full range) for the LC2i to work with and send to the clarion EQ.
heres pics:
got my wires t-tapped
preouts in the radio
LC2i in the glove box
now the EQ
now this is how you REALLY notice the odd shape of my glovebox lol
not exactly what i wanted, but it will do for now, i have access to both units at anytime which is what i was really wanting, but woulda just been better to keep just the lc2i in the glovebox, and the EQ in the center consol, but oh well
hoping to finish this up tomorrow as well as getting hopefully all the deadener in on the hatch, whole cargo area and hopefully have enough for like 5sq ft. in each door
Team Sundown Audio
nice car ! saz 1500 v3 and sax 125.4 my guess for amps. :popcorn:
correct :)
the 125.4 i actually preordered way back in may when it first started, before i even planned on getting a new car, and the 1500v.3 i literally preordered like 10 seconds before it closed lol. my original plan was a 2500v.2 but they got pushed back to late november instead of october, which i still may get one
but equipment list is as follows:
sundown 125.4
sundown 1500v.3
sundown z15v.3
audiocontrol lc2i
clarion eqs746
2x xs power XP950s (for now, can fit 9 in my tire well for any time later lol)
audiotechnix wiring
Team Sundown Audio
I am very interested in one of these cars. Can you show some detailed hatch pics? I want to know if I may be able to fit 4 12's in one of them. I will only own a hatch or suv and I at least need something big enough for equiptment.
Also I was going to guess that you would be using a 2500d. I am curious to see how the 125.4's stack up. I may have to upgrade my 100.4 to get one.
I will be watching your build. I like the start and as you already know an alt is a top priority.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
my plan was a 2500v.2 cause they were originally supposed to be here beginning of october, but now got pushed back 1.5 months so im getting a 1500v.3 for the time being, and as for the alternator i cant find one for this car anywhere, mechman doesnt make one, ea, even checked ohio gen, singer prolly could but i'll never touch one of his units lol
but as far as fitting 4 12s go itll be pushing it, the only limit is height, but you can pull out the whole floorboard to gain about 4.5-5" 36 max width, 31 max depth, the box i have now is 14.5" and is about 1" away from the top of the rear hatch when close in the rear. doesnt have the best angle to it though
Team Sundown Audio
however, i did finish wiring up everything in the glove box, and got the RCA cables ran, also ran the 1/0 power run as well for now. also was able to deaden the rear hatch and the cargo area
glovebox all powered up
car gutted for deadening
now, i didnt plan to deaden the area where the rear speakers are, however i had to remove those panels in order to remove the rear hatch panels, so i did about 2.5sq ft of deadener on each side
and i forgot to take pics of the hatch, but im sure youve seen a deadened hatch lol
power wire being ran
Team Sundown Audio
new vid:
Team Sundown Audio
well got one more thing, well two, in the mail today
couple batts from XS Power
two of these should be sufficient enough for now, if not, can always buy more lol
now just waiting on sub and amp which should be shipping end of the week
Team Sundown Audio
real nice
06 Trailblazer ss
2 Team shok industries tsx 18s
Phoenix Gold ''THE ONE''
2 Phoenix gold 800.4
4 crescendo mp6.
2 crescendo mp8
bass processor
Dc power 270xp
150ft 1/0 ofc sky high cable
1 juicebox lithium 0.5kwh 14v/40ah
kenwood dnx8120
BCAE1.com
YouTube channel : REaudioxxx1
build log: http://www.stevemeadedesigns.com/board/topic/160106-trailblazer-ss-xxx/
  • Who's Online   0 Members, 0 Anonymous, 676 Guests (See full list)
