CONTACT ME VIA Email! I do not login enough here lately to respond daily. Jmilcher at gmail dot com
1. Product:
Audioque 2200d monoblock amplifier
2. Specs
Audioque Amp Specs:
Specifications Model AQ2200D
Digital Monoblock 1 ohm stable
Variable Low Pass Filter: 20Hz-200Hz @ 24dB/Oct
Subsonic Filter: 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Clipping Display Led
External Fuse Rating 200 Amps,
Tested Voltage 14.4V
4 ohm power @ 12V 500x 1
1 ohm power @ 12V 2200 x 1
1 ohm Power @ 16V 2500 x 1
3. Description/Condition:
Audioque 2200D:
10/10 cosmetic
10/10 mechanical
Used with (2) D3400's and a HO alt with 1/0 stinger wire. Never dropped below 13.4 volts! Great sounding amp, and with proper electrical it generally does more than rated (do your research, you will see)
Comes with the original box, manual, quality control birth sheet, and the bass knob. I did unhook the blue light in the bass knob (power light) because it was annoying. It can be solderd back if need be. The CLIP red light is still on the knob and functional.
This amp was used by me personally less tahn 5 hours with the sub. They were in a show car and only played for demos etc at shows. It wasnt a street beater or abused etc.
Amp is like new, and works perfect. It was very well taken care of and properly powered. It was not abused, and never had a single issue whenI have owned it.
4. Price: :
Audioque Amp:
$330 . I will consider a slightly lower price possibly depending on the shipping charge. Comes with all the original stuff.
LOWERED to $290 + SHIPPING. I NEED THIS GONE ASAP!
5. Pictures:
Feedback:
Ebay: my_ride_has_bass (300+ 100%)
Heat: jmilcher
CACO: Check the foum, feedback :jmilcher
SMD: Bought directly from Cody, and a few others in the last 2 years.
Contact me fastest by email. jmilcher at gmail dot com
I will respond to PM's but it may take a day or so.
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
Just what I need, another AQ2200.
If you still have this within a few weeks I may be able to take it off your hands. Got other stuff I need to buy first.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
If it is still here you are welcome to it. I have it priced a tad higher than some other ones without the boxes manuals etc I have seen on here in the past. But it was very well cared for and includes everything... so it may still be here.
Where in mi are you located?
I am in Battle Creek, Michigan
could you pm me a price for the 2200 shipped to 66749? may pick up payday if shipping isnt high.
1995 Integra GSR (DB8)
Pioneer 3200-DVD
6.5 rockford fosgate 2-way fronts
6.5 rockford fosgate 3-way rear
saz-3000D
(2) 12" SA-12s
Whats the zip? That zip had too many numbers
That is the zip
Pioneer 3200-DVD
saz-3000D
(2) 12" SA-12s
That is the zip
Sorry man late night! I will check right now and get back to you
