My lights still dim even with a second battery.
I have a 2004 Infiniti M45 if it still dimming im assuming i need a better car battery or a H/O alternator the amp sucks alot of power and when it does my car revs really funny and doesn't rides smooth any advice? XS Power or Optima and/or H/O Alternator? i have a budget......
Product List Installed:
Stock Head Unit Converter
Capacitor
Dry Cell Battery
2G Amp Wiring Kit
Rockford Fosgate T1000.1BD Amp
Rockford Fosgate 2 12 P3 Subwoofers with dual ported box.
you need better wiring. big 3 in 0 gauge OFC!! make sure your engine grounds are good!!
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Do your big 3. Watch a few videos to see it done different ways, some are better than others. Do it in 0ga. Basically, what ^ he said. Doesn't sound like your electrical is strong enough to carry a cap either.
buy 1/0 AWG wire by the foot with ring terminals, and cut a length for
a. alt+ to batt+
b. Batt- to engine bolt, like an alternator mounting bolt
c. batt- to frame, strut tower is easier for some people to get to
solder the ring terminals on the end of the wire and bolt them down.
Sorry, but i'm a noob :/ explain to me what engine grounds is and what u mean by 0 gauge wiring? for amp kit or for battery to alternator?
You have to be willing to do lots of research. Run 0ga wherever you can, but definitely for your big 3. Your battery should be grounded to the frame and to the engine. Also run 0ga from alternator positive to battery positive. I recommend fusing this wire but not everyone will, it's just an extra safety measure.
again, get rid of the cap, and I suggest you pic up a volt meter so you can see how far you drop. If you need a really cheap one, I've had good luck with this one http://www.sonicelectronix.com/item_38984_Xscorpion-DVM3RB.html
the refresh rate is fast but it's better than nothing and pretty accurate for the cost.
