Subs thump when goin over bumps ?
Just recently in the last couple days I noticed that my subs thump and make sounds with the bumps in the road.... Would it be most likely that the rcas are at fault? I checked it out real quick before I went to work this morning and the rcas are plugged in and my ground seemed to have a good contact (from amp to batt)
My buddy had that problem was RCA's
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
I had the same problem, and found out, could of been of two things.
One being, the battery ground. Even though my amp was grounded to my battery, it would still make sounds and shit while driving. Found out it came loose.
Second, my radio ground somehow got torn and pulled, and I'm assuming that was part of it. You could jiggle the wire and it would make sounds.
Just what i think from experience.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
RCA's. I noticed when messing with the cable that the subs would hit, like if I were to drop the cable from 2 ft then once they would hit the floor the subs would hit. I just got a more expensive type of RCA and the problem went away.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
  • Who's Online   0 Members, 0 Anonymous, 770 Guests (See full list)
