New to sealed boxes, just a quick and probably easy question
IKnowImLost224
I would put the infrasonic/subsonic at the fs of the woofer and the put the lpf at whatever sounds good to you. going above 80hz may let too many vocals through, just experiment. You can lower subsonic if you like and don't have issues with bottoming out.
Subsonic only if the box is way large for most cases, doesn't hurt either, set it to 22Hz or so, LPF depends on your front stage, try around 60-80Hz and see what you like.
rockford fosgate says to turn the infrasonic filter off when using a sealed enclosure. trust me, ive been all over this as i only run sealed. high frequency can affect the sound output on a vented enclosure so they say to use the filter when running ported.
  • Who's Online   0 Members, 0 Anonymous, 3620 Guests (See full list)
