n8ball2013 Posted September 9, 2012 Report Posted September 9, 2012 its a control module for something but it has a detachable lid so I took the fuse holders and a piece of plexi and used plastic adhesive to bond them together and then the piece of plexi to the lid. If I need to get it off I can its just a lot of work. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
TylerParrish Posted September 9, 2012 Author Report Posted September 9, 2012 its a control module for something but it has a detachable lid so I took the fuse holders and a piece of plexi and used plastic adhesive to bond them together and then the piece of plexi to the lid. If I need to get it off I can its just a lot of work. nice man, looks really clean. I'm kind of thinkin about goin with the Pelican idea of flashlight's since i really like that and everything would be water proof, also a plus. But idk what it is or where to find it What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
ear2ear Posted September 9, 2012 Report Posted September 9, 2012 It also helps to know the other pieces of the puzzle. Are you getting new battery terminals - and what do they look like? Is one fuse holder for your big 3, and the the others for runs to the rear? '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3
TylerParrish Posted September 9, 2012 Author Report Posted September 9, 2012 It also helps to know the other pieces of the puzzle. Are you getting new battery terminals - and what do they look like? Is one fuse holder for your big 3, and the the others for runs to the rear? I'm about to get an xs s3400 for upfront and I'll just be using the screws it comes with, so no battery terminals at all really, and yes, 1 is for the alt, 1 for running to where the batts will be in the back, and 1 4 my 4 channel in the back (there currently aren't any batteries in the back so I'll have a run of 4 gauge from the front until then. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
KillaCam Posted September 9, 2012 Report Posted September 9, 2012 I have like a second firewall divider type thing, just secured to the side of that. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
TylerParrish Posted September 9, 2012 Author Report Posted September 9, 2012 I have like a second firewall divider type thing, just secured to the side of that. Wan't it to be as close to the battery as possible What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
ear2ear Posted September 9, 2012 Report Posted September 9, 2012 I only have 1 run to the rear, but could you fit 2 of them on the side in front of the strut tower like mine? '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3
TylerParrish Posted September 9, 2012 Author Report Posted September 9, 2012 No, right in front of my strut tower is my fuse box, that's why I was gonna mount em on there. Went out and checked, I can fit all 3 on my fuse box...but it would be a tighter squeeze than tryin to fit my dick inside a virgin....but i might try it, worse to comes to worse, I can make a little mdf platform for now What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
sphinxbccp Posted September 9, 2012 Report Posted September 9, 2012 I took a piece of plastic, mounted the holders to it, then used a piece of back strap to mount that Build log: Click Feedback: http://www.stevemead...xbccp-feedback/ 03 Chevy Blazer - IPad Air 2 - ALPINE Head Unit - 4 DC XL 18s - 2 DC 3.5k - ALPINE TYPE R 5.25 COMP - 3 ALPINE TYPE R 6.5 COMPs - DC 175.4 - DC HO Alt - D3400 - 4 XP3000s - KNU 0ga - 60 SqFt Damp Pro Lots more...
TylerParrish Posted September 9, 2012 Author Report Posted September 9, 2012 sounds easy enough, sounds like that would be alot easier than some mdf. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
