How to figure the displacement off oddly shaped things?
pi * radius squared is just for the area of a circle. you gotta multiply that by the length of the cylinder, then divide by 1728 to get it in cubic feet
and don't take the volume of the 45 in the port out of the box. that doesn't factor into bracing displacement
why doesn't that count towards bracing displacement?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
and the 45's weren't complete triangles
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
The piece of wood you cut wasn't a triangle itself, but when placed in a corner you are figuring the volume it took away from the box since that area is sealed off and not "useable" by the SW.
Edit: the triangle (triangular prism actually) is formed by the 90 degree corner and the surface that faces the inside of the box. That whole area is being displaced
touche
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Something else i found is if you use the line tool and draw a line at the terminator of your port on the bottom of the enclosure you can select just the bottom of the box minus all the extra junk that is in there and get the area of that. Then multiply times height / 1728 and you should have your total cuft. It won't work for every box design so you may have to use some common sense to make it work. But it will save you some math.
Fill it with water, then empty water into a measured container, like a 1 cubic foot box. Of course, that method isn't very practical for a wood box that isn't protected by resin and waterproof. This method works really well for figuring the volume of a really odd fiberglass molded shape.
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
in that box you posted i would draw a line across the end of the port from the inside corner of the port wall (where it starts in the box) to the other port wall. Then you can just select the bottom of the box and get the area.
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
