2 18's low-end monster
MIKE-2U
You're gonna love two 18s in your Navigator. I've got an Escalade that I just finished putting two 18s in...on only 1860 watts at 11 cubic feet and I'm loving it! Different subs, so my specs wouldn't help you any, but I'm glad I listened when others said subs up, port back. Good luck and take pics along the way and post them here!
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
I will start a log when i get goimg. Gunna take 3 weeks or so. Im really excited though:)
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Did you use mdf ?
keep the port on the smaller side of the 12-16 sq in per foot and it will play a wider range usually. Like mine is tuned to 31hz, and plays down to 24 no problem and still plays 60s extremely well with 11.8 per cube.
Did you use mdf ?
Lol....it would be easier if I just gave you the link to the build. The short answer is yes, 1.25" MDF. The long answer will be found in the link below...
http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-1467db-video-on-page-11/
Two RE SX 18" subs
The lower FS of the 18s will naturally make them pick up lower notes a little more so than a smaller driver (IE... The current 12s you're running in your car).
If you're not intending to play chopped and screwed music, I'd tune to 34 and call it a day. Sounds like you intend to play normal music.
Playing mid to high 20s won't be an issue until you add more power.
Going from a trunk car to an SUV, you'll be happy.
Whatchu talking about Fs and lows?
My 12s have a Fs of somewhere around 45hz and I peaked at 28hz, could jiggle balls at 24hz no problem and I was tuned to 30.
Thanks for all the help everyone
Did you use mdf ?
http://www.stevemead...deo-on-page-11/
Wow box looks amazing! the only reason i asked is because i dont know if i want to spend all that money on birch the first dual 18's box i build. in the future, yes i will as i better my skills. I dont have a table saw so its impossible to cut good cuts. so you used 1.25" mdf single layer ? The only issue i worry is that it will be so heavy the air ride suspension will have issues. .
"fs: Driver free air resonance.
The point at which all the moving parts of the driver sympathize or resonate. Resonance is a hard thing to explain simply, but a rule of thump is that you will find it hard to produce lower frequencies than the driver’s fs. So a driver with an fs of 60 Hz will not produce 35 Hz very well. A driver with an fs of 32 Hz will produce 35 Hz, if the box is tuned low enough. These two examples relate to closed, ported and bandpass cabinets, horns are less affected by fs as they use the driver as a piston."
Every tangible object has a resonant frequency. Larger diameter drivers (generally) have a lower resonant frequency. Only exception would be a standard voice coil configuration on a larger sub vs an underhung voice coil on a smaller sub.
  • Who's Online   0 Members, 0 Anonymous, 1703 Guests (See full list)
