TylerParrish Posted September 13, 2012 Report Posted September 13, 2012 Look around on the for sale section for some good deals. And I say start with headunit, then if you're happy with your current stock speakers. Go sub stage until your stock ones are no longer enough for you. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
coutrybasshead93 Posted September 15, 2012 Author Report Posted September 15, 2012 Did you typo your own username? My suggestion is to slowly piece together your system. Start with a good headunit. I suggest pioneer, kenwood or alpine. I prefer Kenwood and the eXcelon units to be more specific. Once youve installed that, get some door speakers. I'd suggest a 6.5 component set for the front doors. Get a rear set of coaxials or components if you prefer. Then get a decent 4 channel amp for the front and rear soundstage. At THAT point you should get a substage and your sound will keep up. For your space 2 12s would be just fine for starting in a ported box tuned to mid 30s. Brand doesn't really matter at this point. I'd search around and see if anyone is running any of the equipment that the forum likes, for example, DC, Skar, Sundown, Fi and so on. The prices are good and performance will be phenomenal if the box is built correctly. Biggest part of the install will be the quality in which it is done. Biggest important thing for me to have a good sounding system is SOLID electrical connections and a well thought out and built box. Yes I did typo my name, I didn't realize until just now lol. I was recently Thinking about a new head unit, I mean I currently have a Sony, but I want something better. I am alright with my current audio with my speakers which are aftermarket Sony's, but I will upgrade later down the road. All I am really just looking for some bass and better head unit. Thank you for your information, it was very informal.
coutrybasshead93 Posted September 18, 2012 Author Report Posted September 18, 2012 it was very informal. LOL. I think you mean informative? Anyway, what does that $700 cover? Just subs and amp? Subs, amp, and head unit? You know what I mean. Well, I thought about pushing to $1000, so I could get something a little bit better than with $700. I'm going to use the $1000 for the amp and sub(s)
DylanBunch Posted September 23, 2012 Report Posted September 23, 2012 2 sa-10s or 12s = 350ish maybe 400 rockford fosgate t1000-1bdcp 400 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
AAKSOKOLD Posted September 23, 2012 Report Posted September 23, 2012 tc epic 10's, jvc arsenal and apsm mini. Me & My DJ*!
CleanSierra Posted September 23, 2012 Report Posted September 23, 2012 tc epic 10's, jvc arsenal and apsm mini. Weirdest combo of equipment I've EVER seen suggested. The JVC Arsenal is a good bang for your buck that's for sure(built by Kemwood now and 4V preouts). The audiopipe is junk, CHEAP, but junk. As for the TC, another great choice and under the radar too. You might as well suggest he tries his first build as a T-line or 4th order too? Keep it simple OP, getting a good HU, followed by wiring, door speakers, amp for door speakers, wiring for Big3, wiring for sub amp, sub amp, subs, and box built correctly IN that order. Stick to a simple ported design at first either using a slot(L-port) or aero ports(which are just round ports with flared ends). PVC works as well for a port material. Im not the one you want to try to troll. Just a fyi for you.
imnew59585 Posted September 23, 2012 Report Posted September 23, 2012 Well for a 700 budget, you can get some obsidans or American bass TNT for like140ish , now about the box it should run about 70-100 depending on wood and supply cost it would run more with fiberglassin it,the amp you can buy a name brand for 300 , but the 1. is ELECTRICITY , your factory wires will not do enough ,do the big three in 0ga, maybe a second battery (if your aalternator can handle it.) That budjet should run 700-800, without head unit. But one key to save is buy used equipment, like your wire maybe a amp, **but for the subwoofer brand those two was the two on my mind there is others but its to early to think.
HunterJohnson Posted September 23, 2012 Report Posted September 23, 2012 http://www.stevemeadedesigns.com/board/topic/151331-fs-sundown-saz1500d/ http://www.stevemeadedesigns.com/board/topic/151845-aa-chaos-10/ great stuff at good prices Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
