XS Power
.5 ohms vs 1ohm on my electrical.
That only tells you what your box rise is at 1 frequency though. That is great if you are competing and do burp only, but how does that help you in a daily setup?
Now do the same test from 25-65hz in 5hz increments and then you will have useful info.
edit: Damn jetta ninjaed me. I was nicer though!
I love this part
"when it fluctuates you're better off letting a damn monkey throw a dart at a poster board with random numbers written on it for your rise"
Edited by CJ18
I love this part
i understand that its just to get an idea man never had a problem out of my amp being wired at .5 ohm..
Edited by Jman08
Youtube.com/J Hutch22
lol soooooooooo you cant explain it to me? then
is that why your getting mad cause you don't know and i was right?
its very easy to tell someone what they don't know by comments like that.... if you understood anything about ohm rise you would of never said what you did
Clamp and multi meter i just burp my peak freq and divide..dont like that you just assume i have no idea about the concept thats all
lol thanks for proving my point
incase you need help on my point you do not have a concept of it at all
soo go ahaead and tell people the false info of your ohm rise will be over 1 ohm and your good
Edited by Team Bassick (ALPINE)
Just an idea isnt useful info though when you are talking about wiring below 1 ohm. Most amps are 1 ohm stable. What this means is if they see much below 1 ohm reactive then they will go into protect. Your actual reactive impedance is going to be much lower on the lower notes than it is at your peak frequency.
Here is an example for you from a clamp test I did on my 7.5k.
Here are the rated specs for the 7.5k.
Features Voltage 7.5kw
Output Power (RMS)
at 4 ohm 14.4V 2200W x 1
at 2 ohm 4400W x 1
at 1 ohm 7500W x 1
at 1 ohm 16V 8600W x 1
at 1 ohm 18V 9200W x 1
This test was done in my 2006 Ford F150. I am running 1 Mike Singer 350a alt charging my 5 XS D1400 14v batteries at 16.4v
Voltage started at 16.4v.
Starting impedance is .67ohms
HZ----AMPS----VOLTS----WATTS----OHMS----Voltage Drop
30----mega_shok.gif.9----96.5----7806.85---1.19----15.2v
35----78.2----100.2---7835.64---1.28----15.2v
40----72.2----103.6---7479.92---1.43----14.1v
45----62.2----107.8---6705.16---1.73----14.7v
50----61.5----106.9---6574.35---1.74----14.7v
My starting Impedance was .67 ohms. As you can see, the lower hz of the tone played, the lower my rise was. Now consider that my peak frequency in my truck is 48hz. At 50hz, I have 1.1ohms of rise from .67 to 1.74. Of course I am going to be fine here, but down at 30hz, I was only rising from .67 to 1.19. Now if I were to drop back and be wired to .5 ohm and saw the exact same numbers, at 30hz I would be at 1 ohm reactive, but what about a lower note? I may have only seen .85 reactive at 25hz and either sent the amp into protect, or could have possible blown the amp.
This is why all of these numbers are useful for a daily driver if you want to run below 1 ohm.
I love this part
:D mine was seemingly nice, i just use swear words
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
Output Power (RMS)
at 2 ohm 4400W x 1
at 1 ohm 7500W x 1
you can't forget the fact that everytime the sub stops it drops to (in your case) .67 ohms then rises from that point so in daily your amp will see .67 ohms a lot of the time
said "i would wire it to .5 ohms more than likely you will be over 1 0hm after rise..or would at least test it out"... Yes i do know how to caculate rise and do have a concept of it. Reason why i clamped using the peak frequency is because i wanted to see how much power my amp was putting out at my highest termlab score..could of tested it on music but could care less.
Put my system in at .5 and everything is fine voltage is the same as 1ohm, amp gets Luke warm after about 10-15mins. So I guess the optima yellow top is fine for 1200 watts.
2 weeks later...
  • Like (+1 Rep) 2
  • Who's Online   0 Members, 0 Anonymous, 1789 Guests (See full list)
