4 Cylinder vehicle VS a Wall
Question -Would a wall, lets say 4 15's in a 4cyl be too much stress on the vehicle? Transmission wise and what not. Let me know what you guys think. Btw the car would be driven as a daily driver -thanks
depends.. on the driver side door at the bottom look for max load..
add up all the weight and see.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
The transmission's job is to take power from the engine and send it to the drive axle. In the case of a front wheel drive vehicle, the transmission and drive axle are one piece called the "transaxle" (clever right?)
running oodles of electricity through your system deals with the alternator and battery. Neither of which are connected to the transmission.
Source: Parrot Asteroid Smart
Processor: Digital Designs X1
Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400
Front stage: Hertz 165xl + HL 70 + HT28
Rear fill: Hertz 165xl
Subs: 2 SA-12's
3-way active ftw
I picture it being most stressful on your suspension
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
i have no problems 4 banger with 7 batts wall and 12 10's
it does have an si motor tho and manual transmission
the car sits at stock highth as well with upgrade honda accord wagon springs as well
half this post is true, though sound system has nothing to do with the transmission or connected to it the weight does effect the transmission.. try loading your car with people and check how long it takes to shift. all it does is burn up your fluid and clutches..
What i meant by the transmission part was, would the trans hold up against all the weight in the vehicle.
I guess the pic's make a strong point about 4cyl vs walls haha
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
