My electrical is 65ah vw stock battery and a 140amp stock alternator with stock wiring. I have a brz1200 running 2 12's at 1 ohm. I have been having some issues with voltage where it will be at 14.4 when i start the car and after 30 mins of bumpin it struggles to return to 14.4 and kinda hangs out at 13. I thought the problem was in the grounding.
I ended up not messing with that ground too much. I did not have the right tool to remove it so i just left it. I like the idea of adding another ground wire so I will try that.
I am in the market for a new battery or whatever so don't be afraid to suggest that. thanks
If I were to buy a big 3 kit It would be from ce auto electric supply. Check out member snafu and read his posts on the big 3, chances are you will learn a lot.
  • Who's Online   2 Members, 0 Anonymous, 1178 Guests (See full list)
