What's that connected to? That's not a good ground bc it looks like its welded on there. I assume that's a front battery ground? Just go straight to the strut tower
If it is all welded I would say it is a good ground but it doesnt look welded. It looks to be a little loose. is it?
2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/
Kenwood 352U HU
(2) Incriminator Audio Death Row 12''
Soundstream Tarantula 1300W
MTX 6.5'' mids &
Infinity 4x6's in front doors
Building as money comes in... beauty panels and amp rack
1996 Jeep Grand Cherokee Traded for a 2004 Malibu
2wd-4wd conversion
4in. lift
32'' Tires
2 Alpine 6.5 in front
2 Sony 6.5 craploads in rear
Build: http://www.stevemead...__fromsearch__1
1999 Suzuki Sv650(Work in Progress)
If that bolt isnt welded on there sand the metal piece to bare metal and it will become a good ground.
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
Yes it is my front battery. I was wondering because I don't see any bare metal contacts and its not really coming in contact with much other than that spacer underneath it. I will see what I can do with it thanks guys
yeah you need metal to metal contact! Just sand that down to metal and stick a different bolt through and you will be set.
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
What would sticking a different bolt threw it do? Not being a dick here but those kinds of grounds are bad. There's weld spots and it's not a solid piece of metal. Ground to your strut tower or frame. If its a unit body car then strut tower
X2
what ever u do, make sure its good an tight. an has a metal to metal contact. no paint or anything like that.
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
