new sway bars and bushings can make a huge difference on most cars
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
strut bars really dont do much maybe stiffen alittle (woops though you staid strut tower bars lol)
get some nice coil overs
if its NA go with the usual CAI and header back exhaust
if its boosted front mount/SSQ BOV/3in turbo back)
if its supercharged get some pulleys
if your mechanically inclined find some crazy lobed cams
or nos it
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
underdrive pulleys, bigger cam, better flowing heads, bigger throttle body, bigger injectors, stroked crank, cold air, headers, mandrel exhaust, ect ect
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
or nos it
BOV's don't add power.. :fyi:
Not to mention, SSQV sucks for making serious power (has tendency to leak).
Stick with OE BPV's, some are good for 10lbs, others are good for 25.
or nos it
lol why would you upgrade a front mount with a sotck BOV
and SSQ is good up to 20+ lbs of boost
i had my HKS on my talon and was pushing around 17psi daily 20 @ the track
now the only good STOCK BOV's are off the 1gen talons like mine... crush em and poof good for what 35lbs? lol
and no it wont gain horsepower but it will release back pressure and prevent turbine surge (where the air has nowhere to go when the throttle is let off quickly so it spins the turbo backwards )
if you replaced your sidemount or even frontmount with a bigger aftermarket intercooler and not the bov and increased the boost id bet a new turbo would be your next upgrade after there is enough shaft play to almost see the fins come out of the inlet lol)
and the best way to fix a leaking SSQ is.....better O-rings adjusting the sping properly (not @ 10 when your pushing upwards of 15psi)
they made the SSQ to be leak proof and better for low end boost....
  • 4 weeks later...
I could have swore the ssq bov was a pull type like a tial so the more boost u run the tighter it seals?
I personally don't know bc I've ran a few sard bovs on my fd or my vr4 but every Dsm I've had I've used a tial or 2 and they didn't leak at 30-40 psi
150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries
