never fucked with 4 channels before, where should the settings be at on the amp, on the radio, is there any secrets i should know before messing with it? just all info you got on the subject.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
I had my headunit's HPF set to off, then set the crossovers on the 4 channel to 80-100hz. I set my gains off a DMM and never had a problem with the mids and highs. I had the amp selection set to HPF.
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
Depends on how your going to use it, if your going with an active set-up you will want to use the onboard crossover, and if your speakers are passive then set it to full pass on both front and rear.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
most 4 channels i've seen have either high pass or low pass on each channel. When i wired mine i used my band pass on my crossover for the mids and put them on channel "A" then high passed my tweets on channel "B". That way i could cut the tweeters back. It helped a lot in SQ in my opinion. You could pretty much do the same without an external crossover but you will probably need some way to keep the lows out of your mids to keep them clean, since most 4 channels you have to pick either low or high pass and can't do both.
That may be a disorganized wall of text but i am drinking captn' and coke.
what's the difference between active and passive?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
i have 2 way speakers for the time being, so im not sure how that would work for them, will be getting a comp set in the near future though. And you lucky bastard, i love cap'n and coke, well jack and coke, it's my favorite combo, but i've really gotten into amaretto, or however you spell it, lately.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
oh and my 4 channel has a full, a lpf, and hpf setting, so i guess full means both?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Full does not mean both, it means full range. If you have 2ways, just run the HPF at the crossover frequency with the subs.
Active is when each speaker is running to the amplifier, passive is when it is multiple speakers running through a crossover that from there goes to a single channel on the amp.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
thanks, seems simple enough. is there an advantage/disadvantage to running passive over active?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
I don't believe there will be anything different in the two, only if you are running between two sets, the same power output and Db Slope. But let's say, you are running a 175.4 to 4 comp sets, 2 in front and 2 in back. Each channels power output would be split between the two speakers. Now if you run active, you can only do a total of 2 comp sets, and each speaker will receive the full channel output. I have seen from people, they say the Active sounds better. I am going to be running active in the future with 2 4 channel amps.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 814 Guests (See full list)
