KenC210 Posted September 21, 2012 Report Posted September 21, 2012 I have an aq 2200 a kicker 650.4 and a cadence 300.2. I am getting a singer alt the best he could get me was a 260a for $375. I have a yellow top up front currently so now with my amps would i be fine with the alt the yellow top and a xp3000 from xs power? I haven't made the purchases on the battery yet so i just asking would i be ok with the yellow top and the xp3000? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Lbox88 Posted September 21, 2012 Report Posted September 21, 2012 Sounds like a good starting point to me, do you have 1/0 throughout already? As in, do you have the big 3 done and a run of 1/0 to the back? UBL | Build Log
KenC210 Posted September 21, 2012 Author Report Posted September 21, 2012 Yes i have 1/0 throughout the truck already and big three. i am just going thru a rebuild and doing it right this time around. I did have stock battery up front yellow top in back stock alt big 3 done with those three amps just had my batteries on a trickle charger everyday. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Lbox88 Posted September 21, 2012 Report Posted September 21, 2012 How's the resting voltage on the yellow top right now? UBL | Build Log
ChevyBoy95 Posted September 21, 2012 Report Posted September 21, 2012 you should be able to pretty easily run that power on the alt, yellow top and xp3k. but if i were you, i would sell the yellow top and get an xs that matches its size. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
KenC210 Posted September 22, 2012 Author Report Posted September 22, 2012 How's the resting voltage on the yellow top right now? Right now i sits at 12.84 you should be able to pretty easily run that power on the alt, yellow top and xp3k. but if i were you, i would sell the yellow top and get an xs that matches its size. Thought about doing that but i have a 1200 budget and the alt battery and fi subs took that much alone. Also i dont even know how much i would be able to get for a used yellow top Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
ChevyBoy95 Posted September 22, 2012 Report Posted September 22, 2012 well XS has a higher resting voltage, so over a long period of time parasitic charge will pull its float voltage to the same as the yellow top. nothing major, but just something to think about (i mix batteries cause idgaf, as long as they are all AGM). Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
