TonyBranch10 Posted September 24, 2012 Report Posted September 24, 2012 Alright guys Im currently getting a 15" SSD subwoofer with a Hifonics Brutus BRZ1200.1D , i have a stock battery and alternator do you guys think i will be fine with that? Senior in High school, Weekend job =/ Ride: 96 Ford Contour Subs: 2 12"s Rockford Fosgate P1's Amp: Sony Xplod 1.2k Mids/Highs: Tweeters: 6 Power Acoustic NB1 and Nb 2 kenwood 6 by 9 500 watts Headunit: JVC
KillaCam Posted September 24, 2012 Report Posted September 24, 2012 Eh the title and your op are kinda confusing. Do the big three with what you have and you should be fine. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
soundstream15 Posted September 24, 2012 Report Posted September 24, 2012 big 3 will be fine id replace the stock battery as well when you have money
ToNasty Posted September 24, 2012 Report Posted September 24, 2012 What is it going in? Whats the ouput of the stock alt etc? ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
gt58 Posted September 24, 2012 Report Posted September 24, 2012 knukonceptz cca isnt a bad choice for the big 3, that stock alt wont come close to exceeding the cca's current capabilities http://www.knukonceptz.com/productMaster.cfm?category=KCA%20Kable
TonyBranch10 Posted September 24, 2012 Author Report Posted September 24, 2012 My fault guys what i meant was will i be ok with stock batteries and alt , with 15 SSD and Hifonics Brutus BRZ1200.1D Senior in High school, Weekend job =/ Ride: 96 Ford Contour Subs: 2 12"s Rockford Fosgate P1's Amp: Sony Xplod 1.2k Mids/Highs: Tweeters: 6 Power Acoustic NB1 and Nb 2 kenwood 6 by 9 500 watts Headunit: JVC
TonyBranch10 Posted September 24, 2012 Author Report Posted September 24, 2012 96 ford contour Senior in High school, Weekend job =/ Ride: 96 Ford Contour Subs: 2 12"s Rockford Fosgate P1's Amp: Sony Xplod 1.2k Mids/Highs: Tweeters: 6 Power Acoustic NB1 and Nb 2 kenwood 6 by 9 500 watts Headunit: JVC
gt58 Posted September 24, 2012 Report Posted September 24, 2012 My fault guys what i meant was will i be ok with stock batteries and alt , with 15 SSD and Hifonics Brutus BRZ1200.1D you should do the big three to avoid voltage drop. dont buy a kit, measure out the lengths youll need with a string then order the correct amount accordingly. shouldnt cost more than 40 bucks, assuming you have solder and a propane torch
Guest Posted September 24, 2012 Report Posted September 24, 2012 My fault guys what i meant was will i be ok with stock batteries and alt , with 15 SSD and Hifonics Brutus BRZ1200.1D you should do the big three to avoid voltage drop. dont buy a kit, measure out the lengths youll need with a string then order the correct amount accordingly. shouldnt cost more than 40 bucks, assuming you have solder and a propane torch why shouldn't he buy a kit? the kits that are offered on here are fucking fantastic. yeah they're kind of pricey, but its all top of the line connectors/etc. if OP has soldering/crimping skills (with an actual 0 gauge crimper, not a hammer/vice) then he can buy the wire and fuses and connectors and do it himself.
MrSkippyJ Posted September 24, 2012 Report Posted September 24, 2012 why shouldn't he buy a kit? the kits that are offered on here are fucking fantastic. yeah they're kind of pricey, but its all top of the line connectors/etc. if OP has soldering/crimping skills (with an actual 0 gauge crimper, not a hammer/vice) then he can buy the wire and fuses and connectors and do it himself. agreed. I would trust the kits available here over a ton of peoples ability (including my own) to solder/crimp 0g terminals F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
