setting Gains With Ohms Law
How Accurate Is The Ohms Law Formula When I Comes To Setting The Amp Gains With A Multimeter?
Wouldnt It Just Be Better To Use The DD-1 To Set The Gains Instead Of Using The Ohms Law- Voltage = the Square Root Of Power x Resistence
2011 Impala
pioneer headunit
rockford fosgate rca's
audio control three.2
rockford fosgates T165&T1692
2 re audio sxx 15's
hifonics brz24001.d
crunch 1400.4
audio technix 10ga speaker wire & 0 ga power n ground
Ohms law won't find distortion for you ;)
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
thanks
2011 Impala
pioneer headunit
2 re audio sxx 15's
hifonics brz24001.d
crunch 1400.4
Better than nothing, but not terribly accurate either.
What you could do (not particularly kind to the amp) is turn your gain all the way up, play a square wave, measure the ac volts value, divide that by the square root of 2, play a some wave of the same frequency, then adjust the gain until it reads as close as possible to the calculated voltage.
Its essentially finding your peak to peak voltage and converting that to rms(sine wave) voltage
  • Who's Online   0 Members, 0 Anonymous, 912 Guests (See full list)
