stock head unit, how to run remote
I got the pac inline converter, but how do I install the remote? Where do I run it too
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
What car is it? year and model.
Don't run a fuse tap.
Eclipse cd7000
Actually there should be an ignition wire going into the back of hu, look up a wiring diagram and wire into that if you don't want to run it off a switch. Should be yellow I think
This is a great idea.
Care to elaborate?
I used a toggle switch when I ran with the stock headunit for a while, still use it actually.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Splice into the Acc turn on lead (the positive wire that plugs into the stereo that only comes on with the ignition) or splice it into the power antenna output, if your car has one. With running it off the acc wire you may want to install a separate kill switch just because the amp would still be on when you turn the radio off with the car is still running.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
If you do the power antenna wire it will only come on with the radio :)
That is correct. I forgot to mention that.
My Saab 9000 build
  • Who's Online   0 Members, 0 Anonymous, 993 Guests (See full list)
