Mazda3 06' 4500 RMS - Tri-Amped Mids/Highs (New Springs - No More Sag!)
Baffle is 4 thick total, the very top piece will be to flush mount the subs
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
got the top on, but not pics yet, it is so damn heavy, just have to cut the sub holes, seal the inside with glue and sand in there :D and wrap it
Pioneer 4300DVD
Finished the box, and I am in love with sundown
Took 45 minutes per hole to cut with that jigsaw, brand new blades
Pioneer 4300DVD
Pioneer 4300DVD
Test fitting on where to mount
Pioneer 4300DVD
the Piece stuck out to far for the bolt to fit, so I cut it :P
Did direct leads, no bolts
Pioneer 4300DVD
No one will be stealing this amp, you can lift the back of my car with it :P
Locking bolt, and a locking washer
Pioneer 4300DVD
Gotta wrap these in that black mesh vinyl I did the amp holders in
So I am in love with sundown, they hit so hard, and its a very clean note, with no delay. My voltage is pretty good up to 33/38 volume, holds at 13.8 around, but once I push up past that, like ful tilt, 38/38, I hit down as low as 11.2 with the voltage, but it dips up and down, many times sticking at 12.3ish or so. I have the biggest alt I can get for my car, and this setup demands around 470 amps of power, on top of the car usage on full tilt, so I would say its doing pretty good. They lowest I dipped was 10.8, but that was after blasting it on full tilt for awhile
To Do:
Cover the Top baffle piece
Run another + 1/0 to the back
Run a - 1/0 gauge to the back
Get a clamp meter to test output
Use the deadener I won in the doors for upped sound quality
Super Glaze the inside of the box Come summer for a harder surface, better airflow
Overall my build sound wise is done, the bass is shaking the EQ and Crossover so much that it is changing the levels for the gains on them, so I may devise a way to spring mount them so they don't get as much shock and get destroyed
Pioneer 4300DVD
  • 3 weeks later...
So Kicker Sent me a new crossover, and I decided to mount them with some shock absorbtion, since the ceiling was flexing so bad that it was beating the shit out of the eq and crossover. it works perfect btw, the eq and crossover just float while the bass hits, the springs keep them centered without any extra vibration, and it takes all the energy out.
I will get a video up soon of it working. This should also help with them overheating in the summer with the extra space between the ceiling, since it gets really hot in this car with all the deadening. I plan to build a fiberglass piece to cover them and put fans in them that may run 24/7, with a very low amperage pull, just to keep them from getting hot, at least in the summer
ALSO:
I shortened the 1/0 gauge run of wire to the back by 4.25 ft, so my voltage should hold better, this cold weather is giving me shitty voltage on high volume, but when its 32+ degrees it holds well in the 13-14's, and at the lowest the 12's, in this cold weather though it drops to the 11's :/ I rerouted it in the engine bay and had some extra in the rear, so ended up with a nice solid piece of cable I can use for something now :P
Old Mount (Directly to the mdf):
New Pictures:
Pioneer 4300DVD
Showing off my SA-12's didnt have my crossover in at the time since it was in repair, they are still stiff as hell, loosening them up :P
Pioneer 4300DVD
  • Who's Online   0 Members, 0 Anonymous, 1666 Guests (See full list)
