Mazda3 06' 4500 RMS - Tri-Amped Mids/Highs (New Springs - No More Sag!)
New Woofer Porn From my Mazda3
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
  • 4 weeks later...
Pioneer 4300DVD
  • 3 weeks later...
Decided to reground under the car from the neg battery terminal to try and combat my unibody frame :/
Hammered it down, then soldiered which you dont see :P
Inverted subs, I wrapped those pieces too
Pioneer 4300DVD
  • 4 weeks later...
Put my subs in normal for DBDRAG in Madison, WI on 4/14/13, also did bass race
I got 2nd in db drag for street b, with 143.7, dash all sealed up
Also got a trophy for best of show :P
and got 4th place in 139.9 bass race, ran out of battery reserve with my 1 d3400 upfront :/
Put some overkill pro in there, brings the mids out better, sharper :P
Some Second Skin on the mirror covers, rattled horribly
533807_10151391637698597_1317685861_n.jp
Pioneer 4300DVD
did some inner panel door deadening and overkilling :P the outer metal doors are already done, this is for the inner panel
Gotta do the 3 other doors still
One of the 4 bolts that holds both cases together fell off, so I took it out and cleaned up the bare metal parts and tightened the bolts
Pioneer 4300DVD
  • 3 months later...
Update on the wiring in my vehicle, the wire is 2/0 electron beam technologies, over .5lb per foot in weight
Pioneer 4300DVD
  • 3 months later...
BIG UPDATE FROM ALL OF THE SUMMER AND FALL WORK !!!!!!!!!!!!!! :D
Well I cracked the Transmission case back in may, so I had to get a new tranny, the mount went out and put pressure in one bad spot, while I had the tranny off I did a new clutch, flywheel, bearings inside and some other gasket stuff, im also updating the slave cylinder, all the hydralic clutch lines, master cylinder, thermost, new belt tensioner, gates green back belt, did a balance shaft delete mod, all new performance motor mounts.
The engine is stiff as a mofo no but it vibrates the cabin a lot, but its worth it :D
Did some mods to put the d3100 upfront now, looks way better! :D
There is the balance shaft which I removed, takes out 4 lbs of rotational mass and like 18 lbs total that cover up one of the cylinders
The James Barone Side motor mount, its very high quality and stiff as hell
Pioneer 4300DVD
Blew both my Sa's after pushing the shit out of them, was clipping a little since I accidentally had the bass boost on on my 3 way crossover when I was at a sound competition, left it on by accident and clipped them bad, so I am running 2 omega 12's that a friend is borrowing me, they weigh about 56lbs each ha ha
This picture is from julyish
Ran 3 runs of 2/0 gauge power wire under the passenger side
Mazda's are so easy to work on and I found a huge grommet perfect to pass the 3 runs through
Was trying to think of how to lay the amps in the tire rack, i figure out the best option in some later pics, you will see :D
Pioneer 4300DVD
Speaker wire runs, around 300 ft in the car :D
The amps have a bout 1/2 inch of space between each one, enough for fan cooling to keep them real cool
The fuse "Box" for the rear :D
IMAG3512.jpg'
Pioneer 4300DVD
Nice tight mounting space for the d3400, doesnt move at all
Nice finish on all the speaker wire :D
Went with all copper lugs from del city this time
All the mounting bolts used to go down and have excess under the car, now I did them from the underside up, and all to perfect length, so under the car they are only the heads of the bolts, and they are all sealed with silcone, so no leaking, unlike before :D much cleaner
Pioneer 4300DVD
  • Who's Online   0 Members, 0 Anonymous, 1666 Guests (See full list)
