dereileak Posted October 3, 2012 Report Posted October 3, 2012 This is my Mazda3, my Baby, I love music to death, all kinds and that is my goal to be able to play any music and sound so damn amazing that you feel like you were in the studio mixing it I listen to everything, from Dubstep - Indie - Movie Soundtracks - Everything,except modern country Link to the Normal Build Log for Comments if you wish <---- Clicky Clicky Headunit: Pioneer AVH-P4300DVD (Parking Brake Bypass, Aux 1: Turn-on From Remote, Aux 2: Automatic Amp Turn off on Remote Start and Manually)Axxess Interface Steering Wheel Control ModuleSpeakers:Full Active Setup - No Passive CrossoversKicker QS65.2 Components (Front Door)Kicker QS65.2 Components (2nd Front Door)Kicker QS65.2 Components (Rear Doors)Kicker QS60.2 Components (Rear window Speakers)Sundown SA-12 (Sub 1)Sundown SA-12 (Sub 2)Total: 2 Subs , 8 Speakers, 8 TweetsAmps:Kicker 10ZX2500.1 2845 RMS (Sub Amp)Kicker 10ZX650.4 (Tweet Amp)Kicker 11ZX650.4 750 RMS (Right Side Mids)Kicker 11ZX650.4 679 RMS (Left Side Mids)Total: 4 AmpsPower:Mechman Alternator Candy Red, 220 Amp Max, 120 Idle (Tested Output) Electron Beam 2/0 (2+ runs, 1 - Run)1/0 Gauge KNU Kolossus Flex OFC Wire (- Wire Run and Alt wires to front battery) 4 Gauge KNU Kolossus Flex (Tweet + Mid Amps Power)XS Power D3400 AGM Battery (Rear)XS Power D3100 AGM Battery (Front)XS Power Intellecharger 12v Charger (Built into the Vehicle)Signal:Kicker KX3 3-Way Crossover (Allows Tweet Crossover Also)Kicker 03KQ30 30-Band EqualizerKicker XW16300 300 Ft Roll 16 Gauge (Mids and Tweets Wires)Kicker XI26 2 Channel 3 Meter X-Series RCA's (Going to Equalizer)Kicker XI46 4 Channel 6 Meter X-Series RCA's (Going to Crossover From Equalizer)Kicker XI26 2 Channel 6 Meter X-Series RCA's (Going to Tweets Amp)Kicker XI26 2 Channel 6 Meter X-Series RCA's (Going to Right Mid Amp)Kicker XI26 2 Channel 6 Meter X-Series RCA's (Going to Left Mid Amp)Kicker XIYF Y-Splitter X-Series (From Crossover)Kicker XIYF Y-Splitter X-Series (From Crossover)Security:Python 592 (Same as Viper 5902 Except has a Cooler Black Remote)Flash Logic FLCAN Bypass Module (Works Perfect)DEI Shock SensorDEI Glass Break SensorDEI Tilt Sensor (Tells me if my car is being jacked up for the rims or towed away )Mcgaurd Security lug nuts (you will not get my rims off with these, highly recommend this brand)Tools:DD-1 Distortion Detector Upgraded Car PartsAudioTechnix 80 Mil Sound Deadener (75 Sq Ft, 3 Rolls) Second Skin 80 Mil (Thanks Steve) Second Skin Overkill Pro (Thanks Again Steve!)Hawk HPS Brake Pads (All Around)DBA Slotted Rotors with Kangaroo Paw Cooling Technology (All Around)Hankook iPike w409 (Winter Tires)Hankook Ventus v12 evo (Summer Tires)Upgraded Throttle Body Ground (Quicker Reaction)Under Foot well Sound Reactive CCFL LightingAdvanced Timing ModThrottle Body Bypass ModCorksport SRI IntakeCorksport LED Lighting KitVCTS Delete Exedy Stage 1 Clutch New OEM Flywheel James Barone Balance Shaft Delete Kit James Barone Racing 88 Durometer Rear Motor Mount James Barone Racing 80 Durometer Passenger Motor Mount TRZ Transmission Mount Coil Spring Specialists Custom Rear Springs (Extra 450lbs) Spin On Oil Filter Conversion Gates Tensioner Gates Greenback Fleetrunner Belt (1/2" Shorter) Redline Transmission Fluid Mobil 1 Synthetic Oil 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dereileak Posted October 3, 2012 Author Report Posted October 3, 2012 July 10th 2011 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dereileak Posted October 3, 2012 Author Report Posted October 3, 2012 Audio Technix 80 Mil Deadner its amazing stuff Roof, All 4 doors, rear hatch door, rear hatch wing are all sound deadend Remote Starts/Alarm ready to put in, Same as a viper 5902, but a black remote instead My Car Looks so bland here compared to now Deadening Time Aug 10th 2011 Triple Layer on the way back, then the middle is 2 layers, the front is 1 layer thick 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dereileak Posted October 3, 2012 Author Report Posted October 3, 2012 Mechman 220 amp alt, 120 amps idle, 220 amps max @ 1700rmp~ The voltage Regulator burned out about 8 months after owning, luckily they fixed it for free This Box is now Gone, going to build a new one for the DC subs These Passive Crossovers are now gone, they caused a lot of issues, go active!!! 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dereileak Posted October 3, 2012 Author Report Posted October 3, 2012 Upgraded the Lenses that the lights shined through with some HIDS, they have an amazing cut off 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dereileak Posted October 3, 2012 Author Report Posted October 3, 2012 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dereileak Posted October 3, 2012 Author Report Posted October 3, 2012 Accidently Damaged some wires, ha ha The metal here is not sharp, I grind ed it to be smooth 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dereileak Posted October 3, 2012 Author Report Posted October 3, 2012 This door was later ripped apart and re done, thats what happens when you teach yourself to fiberglass from the internet ha ha 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dereileak Posted October 3, 2012 Author Report Posted October 3, 2012 Since this box went to the garbage so did the $150 of 3m Carbon fiber vinyl I wrapped it in live and learn I guess Built a Gaming Computer while I did all this too I have lots of hobbies 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dereileak Posted October 3, 2012 Author Report Posted October 3, 2012 This door too was ripped part later to be re done correctly 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
