06' Mazda3 Hatchback - 4500RMS - New Springs (No More Sag)
I now Present my 2006 Mazda3 Hatchback Black 5 Speed Manual :D
Link to the UBL of the Build <-------, this thread since 10/3 is used for commenting :D
Note:
Pictures in This First Post are Dated, and More Building Goes on Throughout the Thread, Enjoy!
Headunit:
Pioneer AVH-P4300DVD (Parking Brake Bypass, Aux 1: Turn-on From Remote, Aux 2: Automatic Amp Turn off on Remote Start and Manually)
Axxess Interface Steering Wheel Control Module
Speakers:
Full Active Setup - No Passive Crossovers
Kicker QS65.2 Components (Front Door)
Kicker QS65.2 Components (2nd Front Door)
Kicker QS65.2 Components (Rear Doors)
Kicker QS60.2 Components (Rear window Speakers)
Sundown SA-12 (Sub 1)
Sundown SA-12 (Sub 2)
Total: 2 Subs , 8 Speakers, 8 Tweets
Amps:
Kicker 10ZX2500.1 2845 RMS (Sub Amp)
Kicker 10ZX650.4 (Tweet Amp)
Kicker 11ZX650.4 750 RMS (Right Side Mids)
Kicker 11ZX650.4 679 RMS (Left Side Mids)
Total: 4 Amps
Power:
Mechman Alternator Candy Red, 220 Amp Max, 120 Idle (Tested Output)
Electron Beam 2/0 (2+ runs, 1 - Run)
1/0 Gauge KNU Kolossus Flex OFC Wire (- Wire Run and Alt wires to front battery)
4 Gauge KNU Kolossus Flex (Tweet + Mid Amps Power)
XS Power D3400 AGM Battery (Rear)
XS Power D3100 AGM Battery (Front)
XS Power Intellecharger 12v Charger (Built into the Vehicle)
Signal:
Kicker KX3 3-Way Crossover (Allows Tweet Crossover Also)
Kicker 03KQ30 30-Band Equalizer
Kicker XW16300 300 Ft Roll 16 Gauge (Mids and Tweets Wires)
Kicker XI26 2 Channel 3 Meter X-Series RCA's (Going to Equalizer)
Kicker XI46 4 Channel 6 Meter X-Series RCA's (Going to Crossover From Equalizer)
Kicker XI26 2 Channel 6 Meter X-Series RCA's (Going to Tweets Amp)
Kicker XI26 2 Channel 6 Meter X-Series RCA's (Going to Right Mid Amp)
Kicker XI26 2 Channel 6 Meter X-Series RCA's (Going to Left Mid Amp)
Kicker XIYF Y-Splitter X-Series (From Crossover)
Security:
Python 592 (Same as Viper 5902 Except has a Cooler Black Remote)
Flash Logic FLCAN Bypass Module (Works Perfect)
DEI Shock Sensor
DEI Glass Break Sensor
DEI Tilt Sensor (Tells me if my car is being jacked up for the rims or towed away :P)
Mcgaurd Security lug nuts (you will not get my rims off with these, highly recommend this brand)
Tools:
DD-1 Distortion Detector
Upgraded Car Parts
AudioTechnix 80 Mil Sound Deadener (75 Sq Ft, 3 Rolls)
Second Skin 80 Mil (Thanks Steve)
Second Skin Overkill Pro (Thanks Again Steve!)
Hawk HPS Brake Pads (All Around)
DBA Slotted Rotors with Kangaroo Paw Cooling Technology (All Around)
Hankook iPike w409 (Winter Tires)
Hankook Ventus v12 evo (Summer Tires)
Upgraded Throttle Body Ground (Quicker Reaction)
Under Foot well Sound Reactive CCFL Lighting
Advanced Timing Mod
Throttle Body Bypass Mod
Corksport SRI Intake
Corksport LED Lighting Kit
VCTS Delete
Exedy Stage 1 Clutch
New OEM Flywheel
James Barone Balance Shaft Delete Kit
James Barone Racing 88 Durometer Rear Motor Mount
James Barone Racing 80 Durometer Passenger Motor Mount
TRZ Transmission Mount
Coil Spring Specialists Custom Rear Springs (Extra 450lbs)
Spin On Oil Filter Conversion
Gates Tensioner
Gates Greenback Fleetrunner Belt (1/2" Shorter)
Redline Transmission Fluid
Mobil 1 Synthetic Oil
Got this Baby on 6/21/11 and I love it!
Day I first got it :D
Wiring setup
Sept 18th update pic:P
Got My D3400 In Already! (Old Pic, lots of new Wiring going on now :D)
D3400!
Subs will Fit Side By Side! Gonna Have to really work this with 4 amps and 2 15's, 8 crossovers XD
THESE PICTURES DONT SHOW ALL THE EQUIPMENT, OLD PICTURES
I love Kickers Stuff! Hope you will Enjoy this Build, will be doing Videos and Pictures all the way through it! I really want a Kicker Sponsorship! I decided just to go all out and go 100% Kicker Besides on Power Supplies which they don't Make! I love the Quality of there Higher end Stuff and Can't wait to make my Hair stand up on my arm!
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
dam cant wait to see what car all that kicker gear goes in, i love kicker also
2004 Escalade Ext
Pioneer avh8400
Kicker ix500.4
Kicker ix1000.1
Kicker hyperflex 0+4 awg
Sundown X-15
Sundown Sa-6.5c x2
KnuKonceptz 4 channel Rca
Rockford Fosgate 2 channel Rca
SkyHighCarAudio 14awg speaker wire
Build Log
how come your not using kicker wire? looks like its gonna be pretty beastly
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
Yeah if you wanna go all out, finish it with kicker wire imo
1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz7r.png
I might, I just bought the knu stuff, and it is a big better, I might get a roll of the kicker stuff to have, like 160 for 50ft of 1/0 gauge, im fine with not doing kicker for power gear though cause other companies do that very well, I just need a damn car now, lmao!! :D
Pioneer 4300DVD
This^^, and are u sure ur going to have enough bats?
those two batts are beastly, for now they will have to do
only running about 3800 watts rms if you look at what the speakers can take, the alt will help a lot
Pioneer 4300DVD
:popcorn:
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
  • Who's Online   0 Members, 0 Anonymous, 1460 Guests (See full list)
