amp white noise help
revoracing247
hey guys, i have a friend who has a Kicker ZX650.4 amp and in one of the channels it just started giving out a lot of static. or like white noise. it gives off the static even when the car is off, and it's like a steady tone, so it's not like an alt whine or engine noise from a bad ground. the amp is like 6 years old. anyways if anyone has any ideas or anything it's be a big help!! thanks!
I think you have a bit of truck stuck in your mud bro
~Ford Ranger, ext cab
Kenwood DDX470
1/0ga stinger wiring for big 3
1/0ga ofc flextech wiring
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
in a 27Hz tuned ported box
LE BUILD LOG!!!
any ideas? i heard i could maybe be from old drying up caps. anyone to back that up?
Kenwood DDX470
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
LE BUILD LOG!!!
yeah i he still want's to use it, i was just wondering if it was maybe something i could do myself cause i do have pretty much all the electronics tools i'd need at me disposal and i really wanna learn more about amps and what not.
Kenwood DDX470
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
LE BUILD LOG!!!
If it sounds like interferance it could be a bad ground. Sometimes Ive seen on cars where the amp is grounded to the body i.e. a seat belt bolt, floor, or bare metal body surface, instead of a direct ground to the battery can cause the white noise or interferencce sound.
  • Who's Online   1 Member, 0 Anonymous, 1526 Guests (See full list)
