Jetta Box Build for 2 12s, ideas?
Jordan Guess
Gotcha. My problem is that I'll be trading my 15" to my friend who has two fully loaded Fi Q 12s but they are D2 (I feel that the Qs could be worth more than a frankenwoofer tc sounds lms 4000). Which means I'm gonna have to sell those to get some d1s or 4s it seems, unless I can find a trade across. Any idea what the running rate of a fully loaded Q is these days that's used? (Reason why I asked about the .5 ohm is because of the Q's). But no upgraded alternator, only the 120 amp stock one. Would that be able to charge a second batt wired to the back and leave me okay with the Aq2200 at 1 ohm?
.5 sucks juice and fast. if you can keep voltage up the amp should be find because you will get rise. but extra battery for sure. worse case get the subs and learn to recone.
i figured ide save myself money by selling the two Qs and buying subs that can match the AQ2200 though (fully loaded Qs seem like they could handle much more than 1100 each)? i dont think i could get 2 amps cheap enough for the value of the AQ2200 could i?
I was thinking that you could keep your subs, if you ran two amps. Your right about the
cost of two amps being more money, but it's still better than running .5ohms. I'd run at
2 ohms with the amp you have not .5ohm. Just way too much stress on equipment. Imho
  • 1 month later...
Dude drop that aq to .5 I would just throw a big battery In the back you should be good on voltage
97 cherokee
2x 15 ns v1@32h
crescendo 5500 (soon to b ns-1)
xs d3100's
  • Who's Online   0 Members, 0 Anonymous, 2129 Guests (See full list)
