Blew Out Another 28" Tire and Wheel....Carnage Pics Inside!
this is y i wont do rubber bands sorry bout youre luck was hoping to see that box in slo
american bass 1100.1 2 hertz hdp4 m&h amps hertz xls audison voice mids and highs 4 fi hybrid subs 1 xs power g31 batt and 6 banks of maxwell caps big 3 mechman 270 singer 350 and another singer 300 amp alts 7 runs of 4/0 TEAM bass drop meca s4 2011 153.7 db at headrest 4 15s
damn, didnt know that happen, looked all fine at the show, infact i was checking out that tire to see if they had air or not
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
Will a tire pressure monitor system fit under those rubber bands? If so might be worth installing.
it should, it sits in the drop center of the wheel usually so it should be no problem
some wheels have two valve holes aswell one for a normal valve and another for the tpms
OP if you need new sensors hit me up ill hook you up with a set for cheap :drinks:
I had the factory Cadillac sensors on my last wheels. The tire shop I bought the wheels and tires from said they would fit, but that they most likely wouldn't live very long before being damaged by the road because they are so close to the tire. Do you have an option that is lower profile than the factory units?
the sensors should be fine. I am on 25 series tires on the Lex and there is no problem. The sensor might save you from low tire pressure damage but won't do anything for a pot hole :D
Follow my Tweet (Twitter)
Just had the GM sensors removed from the old 22" wheels I had in my shop. Gonna get them installed on Thursday so this madness will stop. Gonna drive REAL careful until then.
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
i agree with having cheap tires i also run Pirelli and they hold abuse. another tire that surprised the hell out of me are the lexani 9 tires witch i use on my daily very reliable and hold lots of pot hole abuse trust me i know especially driving everyday on 25 series.
REFF'S
My link
EBAY
http://feedback.ebay...ck&myworld=true
I love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
that would work, the once i can get are just normal size, rubber stem with sensor on the bottom of it like this
there is also band sensors...were the sensor goes onto a steel band that wraps around your wheel, it sits in the drop center of the wheel it would fit with no problem
another thing with sensors in low pros is you want to run higher pressure than stock tires and sometime it sets of the tpms light bc of it
hope it works for you, truck looks sick with the wheels on there BTW :good:
  • 4 weeks later...
seems like u got on some clear/antyre/hp tires thats the main problem there. those tires scream cheap quality.
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
I am not sure if I am late on this or not, but AWD systems really dislike different size tires, even if it only 1/4 of an inch. you can ruin, or lessen the life expectancy by a lot if you run with different size tire for too long.
1996 Ford Explorer Eddie Bauer V8 AWD
So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
