Real96SS Posted October 10, 2012 Report Posted October 10, 2012 This is from their site and the test they have done on this sub. Sub was fine until they put 2 xta5000's on it. Unless I'm deciphering their wording wrong LoL 1. test: amplifier and 1.3 ohms actual output power of 2000 watts rms declared. Track (lil jon bm_click) repeated 2 times about 12 minutes without interruption. Result subwoofer completely cold. 2. test: amplier xta5000D to 1.3 ohms actual output power declared 5000 watts rms, output voltage measured by the meter ranged from 95 volt to 118 volt track (lil jon bm_click) repeated 2 times 12 minutes + track under 30 approximately 2 minutes. Gone are the tests we removed the sub, which was hot on the surrounding coil and warm in the magnet. The temperature was approximately 40 degrees to the magnetic group and 65 degrees for the coil. 3. test: aimed at destroying the subwoofer and see the seal of the speaker and the coil. Same song but 2 xta5000D link in a 0.64 ohm measured by the meter. Output voltage ranged from 168 to 186 volts. The excursion subwoofer was approximately 12 cm -6 +6 cm. The subwoofer is already warm from previous tests he played for about 2 minutes. The coil support has not rectum thermal expansion, it is wound on itself allowing the spool to come unstuck from the support. The coil is still intact and shows no signs of burning, the subwoofer can definitely keep improving this power the coil support. (We will work in the coming months) Vehicle 2007 Chevrolet Avalanche(Co-Co) DNX9980HD 6 Team Fi 15's(King Edition) 3 DC 9k's 8 Nendo PWX 8's 4 Custom Steg 4" Super Tweeters 1 DC Audio 175.4 1 DC Audio 90.4 Rockford 360.3 3 DC Power 370xp Alts(Externally regulated) 21 D1600's 2 D4800's All SMD RCA's AudioTechnix Deadner Viper Alarm My YouTube- http://www.youtube.c...NG?feature=mhee Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/ Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
HHR Ed Posted October 10, 2012 Author Report Posted October 10, 2012 This is from their site and the test they have done on this sub. Sub was fine until they put 2 xta5000's on it. Unless I'm deciphering their wording wrong LoL 1. test: amplifier and 1.3 ohms actual output power of 2000 watts rms declared. Track (lil jon bm_click) repeated 2 times about 12 minutes without interruption. Result subwoofer completely cold. 2. test: amplier xta5000D to 1.3 ohms actual output power declared 5000 watts rms, output voltage measured by the meter ranged from 95 volt to 118 volt track (lil jon bm_click) repeated 2 times 12 minutes + track under 30 approximately 2 minutes. Gone are the tests we removed the sub, which was hot on the surrounding coil and warm in the magnet. The temperature was approximately 40 degrees to the magnetic group and 65 degrees for the coil. 3. test: aimed at destroying the subwoofer and see the seal of the speaker and the coil. Same song but 2 xta5000D link in a 0.64 ohm measured by the meter. Output voltage ranged from 168 to 186 volts. The excursion subwoofer was approximately 12 cm -6 +6 cm. The subwoofer is already warm from previous tests he played for about 2 minutes. The coil support has not rectum thermal expansion, it is wound on itself allowing the spool to come unstuck from the support. The coil is still intact and shows no signs of burning, the subwoofer can definitely keep improving this power the coil support. (We will work in the coming months) Oh Google translator, "Coil support has not rectum" hahaha So with the 2nd test on 5000w and coil reached 147 degrees F. This is below the apparent failure point of over 220 deg F. Breaking point test took it up to about 12,000w on music and the woofer move 4.72 inches. The failure occured at the triple joint where the coil is glued onto the spiders and cone. They then state that they will improve this joint. That's a good engineering mind set. Take a product up to point of failure, see what part breaks and strengthen it. Then repeat test and see what breaks next and strengthen it. This is the biggest reason I like these woofers over Cadence and Lanzar, because there are SPL guys testing and improving this woofer where as the other guys are merely slapping their logo on a dust cap. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
ALPINE408 Posted October 10, 2012 Report Posted October 10, 2012 here ya go how sp audio makes a sub yummy http://www.stevemeadedesigns.com/board/topic/152148-how-spaudio-makes-a-woofer-must-see/ but i saw pics of there subs in a chiner mamufactuing plant????????? Have you ever had your woofers blown?
irpirate Posted October 10, 2012 Report Posted October 10, 2012 I just about picked up 4 15s. Price isn't bad at all considering the sub. Shipping Is kind of a deal breaker though. hiiiiiiii2002 4runner - buncha speakers n amps n shit (gone)1994 astro - more stuffzupdate: pretty sure all the pic links in the logs are broken lol. ma slop garb build log16 12's 4th order4runner rebuild in progressclickkk meeeee!!!! 4 18's 6th orderUBL - clickyhttp://www.youtube.com/yyj11589 lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
