Raptorman Posted October 10, 2012 Report Posted October 10, 2012 I have a single D4 sub. Was wondering if it was even possible to wire it to .5, and if so, how would I do so? I've scoured everywhere and cannot find a guide for it. No I will not be turning the gains all the way up, I'm only going to be pushing around 1750rms while at .5 and the amp is rated for 2100 at 1 ohm. So I'm being conservative. Just would like a straight-forward answer, not the typical (If you don't know don't try it) thing. Thank you! 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
ALPINE408 Posted October 10, 2012 Report Posted October 10, 2012 single D4 sub can be wired at 2 ohms or 8 and thats it man this same question was asked this morning Have you ever had your woofers blown?
Raptorman Posted October 10, 2012 Author Report Posted October 10, 2012 Ah, that's disappointing, and sorry! I couldn't find anything on it, haha. Thank you though. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Kyblack76 Posted October 10, 2012 Report Posted October 10, 2012 http://www.the12volt.com/caraudio/woofer_configurations.asp SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
ALPINE408 Posted October 10, 2012 Report Posted October 10, 2012 I have a single D4 sub. Was wondering if it was even possible to wire it to .5, and if so, how would I do so? I've scoured everywhere and cannot find a guide for it. No I will not be turning the gains all the way up, I'm only going to be pushing around 1750rms while at .5 and the amp is rated for 2100 at 1 ohm. So I'm being conservative. Just would like a straight-forward answer, not the typical (If you don't know don't try it) thing. Thank you! dafuq? how will you only be pushing 1750rms at .5 when the amp is rated at 2100 at 1 ohm why do you want to go to .5? anyways thanks for the laugh tho Have you ever had your woofers blown?
baaudio Posted October 10, 2012 Report Posted October 10, 2012 what alpine said. even with another d4 woofer you wont be able to wire to .5, you will either need 2 dual 2 subs or one dual 1 woofer. even then i wouldnt run your amp at .5. im not sure how you figured you would only get 1750 @ .5 when its rated for 2100 @ 1 Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
ALPINE408 Posted October 10, 2012 Report Posted October 10, 2012 http://www.the12volt...figurations.asp sucks that site only gos up to 4 subs tho Have you ever had your woofers blown?
Raptorman Posted October 10, 2012 Author Report Posted October 10, 2012 Because I would turn the gains down using a DMM and the ohms law calculator to tune to the ACV that gives me 1750 at .5... I'm currently wired to 2 ohm, and only getting around 1300rms. I was wanting to try out a lower ohm load if it were possible. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
baaudio Posted October 10, 2012 Report Posted October 10, 2012 http://www.the12volt...figurations.asp sucks that site only gos up to 4 subs tho jl audio has a diagram that goes up to 6 with multiple configurations.... http://www.jlaudio.com/header/Support/Tutorials/Wiring+Dual+Voice+Coil+%28DVC%29+Subwoofer+Drivers/Tutorial%3A+Wiring+Dual+Voice+Coil+%28DVC%29+Subwoofer+Drivers/287544 Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
