hey. i was wondering if you guys could help me answer a question i had. Im about to buy a new amp for my setup and my friend had a 3000pzi crunch that hes gonna sell me here are the details on the amp:
Product Features :
750 Watts x 1 @ 4 Ohm
1500 X 1 @ 2 Ohm
3000 x 1 @ 1 Ohm Dynamic Music Powers
Illuminated, Large New Design Crunch Logo
Power Supply: PWM
Output Power Circuit Configuration: MOSFET
Frequency Response: 15Hz-300Hz
Damping Factor: >292
S/N Ratio:93dB
THD & amp; N: 0.10%
Variable Input Level Control: 0.2V-9V
Diagnostic Indicator: Power (Blue), Protect (Red)
Variable Low Pass (Mono 24dB): 35Hz-250Hz
Variable Subsonic Filter: 15Hz-35Hz
Bass Boost at 45Hz: 0-10dB
Line Output: Full Range
Unbalanced Input (RCA Jack)
Phone Jack For Remote Control
Dash-Mountable Bass Remote Control Included
Power Terminal: 4 gauge
Speaker Terminal: 10 gauge
Fuse Size: 50 Amp x 2
Im gonna hook up 2 12 inch L7's that are rated for 750 rms each. Would i be overkilling the subs with power if i wired them at one ohm in series (there both dual 4)? or should i just wore them at a 2 ohm load? thanks for your help with any responses
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
Well with 2 D4 subs you can either wire to 1 or 4 ohm
DC.jpgDC POWER
could i wire them seperatley at 2ohms and bring them to the amp seperatley instead of in series together?
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
Kinetik
i think you will smoke them at one ohm unless you set them with a dmm.
Have you benched one of these amps? This amp pushes out 1800 at the most. I would say 1700. Thats like 850-900 per sub. That won't smoke the L7 12s.
2008 Chevy Impala (undercover cop style)
Setup in the makings
x2^^^^ that amp WILL NOT smoke those subs unless you clip it. i assure you that those L 7's will handle that amp just fine
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
crunch :lol: not that good
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
Yeah, when compared to Rockford Fosgate, Jl, or kicker they are not that good but for the money I would say they are the best amp you can get at the cheapest price. If you look at my signiture you see that I have one too. It's not as bad as you think. They actually kind of push my L7s lol. That's why I need to get a better amp. :(
Edited by cichlidfort
I am not familiar with the PZI series of Crunch amps, but I do know that they list the output wattage in dynamic ratings on this amp. Went to the site. The Ground Pounder series is a different story. I read a review on the GP3000 and it actually does its rated power plus a little. I would say try it with your gain set right and see how they react. I bet they can handle it. Kicker has made good speakers in the past and I am sure they still do.
Edited by zaxfire69
  • Who's Online   0 Members, 0 Anonymous, 907 Guests (See full list)
