soundstream15 Posted October 16, 2012 Report Posted October 16, 2012 I use my iPhone for music and when playing full tilt I have the volume on the phone up the whole way, could it be possible it's a clip signal? I thought about this and figured ill ask some of you
Swordlordboy1234 Posted October 16, 2012 Report Posted October 16, 2012 I could be wrong but I thought Meade proved this in one of his videos. If your using the iPod 3.5 mm jack, vs the 30 pin connector (both lossless songs on device) The 3.5 is some sort of amplification especially if you are using the EQ with the phone which at 100% volume will distort. I'd go 30 pin if possible. I got off 3.5 and never looked back. Everything just sounds better IMO. I could have false info, if I'm wrong plz correct me. But I wouldn't post if I wasn't 90+% sure. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Neckbeard Posted October 16, 2012 Report Posted October 16, 2012 You need to test where the distortion level for your head unit is, cant always be running max volume Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/
Swordlordboy1234 Posted October 16, 2012 Report Posted October 16, 2012 You need to test where the distortion level for your head unit is, cant always be running max volume That wasn't his question FYI. he is talking about the iPhone volume using his 3.5 jack at full volume. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Fosgatefeind Posted October 16, 2012 Report Posted October 16, 2012 just get a usb Buildlog: http://www.stevemeadedesigns.com/board/topic/146515-2007-monte-carlo-ls-build-new-plans-with-dc-audio/ TEAM DC AUDIO www.Dcsoundlab.com
Swordlordboy1234 Posted October 16, 2012 Report Posted October 16, 2012 just get a usb USB aka 30 pin connector. X2 ^ this though. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
KillaCam Posted October 16, 2012 Report Posted October 16, 2012 I could never use the 3.5mm jack. Anything in the aux jack just sound like shit to me. Use USB if you can. If not just keep the iPod volume around 3/4 then just adjust at the h/u. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
Swordlordboy1234 Posted October 16, 2012 Report Posted October 16, 2012 I could never use the 3.5mm jack. Anything in the aux jack just sound like shit to me. Use USB if you can. If not just keep the iPod volume around 3/4 then just adjust at the h/u. Also 2x this. My personal experience is the same. But I would even go as far as..... If you can't get USB then get a new head unit that can. (Yes It's that worth it) My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
soundstream15 Posted October 16, 2012 Author Report Posted October 16, 2012 I do use USB most of the time, I have some music that mp4 on my iPhone so that's why I listen to it. I could use my charger instead of the aux cord if that's better, I don't use any eqs on my phone. Should I just turn the volume down a bit on the phone
Swordlordboy1234 Posted October 16, 2012 Report Posted October 16, 2012 I do use USB most of the time, I have some music that mp4 on my iPhone so that's why I listen to it. I could use my charger instead of the aux cord if that's better, I don't use any eqs on my phone. Should I just turn the volume down a bit on the phone If you must listen to the 3.5 jack on the phone I'd keep it below 80% volume. This way has no true way of telling if your actually giving a clipped signal unless you hook up a oscope or a dd1. I'd do it the way that I will never do again... And that's play everything 75% volume. Max HU volume of say 62 x .75 = 46 Same with iPhone. And while we're doing this the ghetto way, set gains like that too. Like I said I'd never do this again. The DD1 is amazing. I know that If I use my USB and 320kbps I'm giving a clean signal to my head unit, and I know that my head unit doesn't distort for 60/62 volume. And I know that my gains are set using the -5db track so on 99% of the songs I've played on my phone sound great and I often challenge myself and other people to listen for distortion. Only 1 track on my phone is recorded too loud where I can't "set it and forget it on 60" is a club mix that I think was recorded at 0db or even boosted higher, and I knew the first few seconds I herd it in my car. Other then that I'd look into investing in those things mentioned above. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
