Need to build a bigger better box but lost
Chris Lamp
I have a 95 Nissan Maxima and I'm trying to build a box for 2x DAD bd 15's in the trunk facing forward. My maximum dimensions are Height-17" Width-38" Depth-27". I'm using the Torres tuning box calculator and the only things I'm having trouble with are the displacements and the port along with any other helpful tips. Thanks
That's strange, those dimensions tell me around 6.5 cubes before displacement of port and subs. You may not be taking into account that a box that's 38 inches wide is only actually 36.5" internally and so forth on the other dimensions.
wondering if the overall width is probably bigger that the trunk opening...
if im understanding correctly..
ok I was doing the outer dimensions, I just built a box that fit into the opening of the trunk but just by a hair, but it's too small so I might have to build it in the trunk, (I had an open topic but it must of got deleted)
I'm trying to make a bigger ported box for my 2x DAD bd 15's in a trunk with the maximum dimensions of H-17" W-38" D-27". The box will be too big so I'll have to build it in the trunk. Can I get some ideas of boxes, I tried using the Torres box calculator but it's clear I have a lot of learning to do.
Ain't gonna happen.
You won't have enough room left for the sub to do what it needs to do and with that amount of room your limited to a pair of 12's comfortably in the trunk without choking them.
You would be better off using only one 15" in a proper sized enclosure than trying to stuff a pair of 15's in there.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
