DubNDodge Posted October 20, 2012 Author Report Posted October 20, 2012 So here's the latest design. Hopefully it can be approved '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Joe X Posted October 20, 2012 Report Posted October 20, 2012 AQ specs say 80 square inches of port at that net volume, a rather big box for a trunk, the DC Audio 12s can work in 1.5 cubes per sub. many other brands fit in smaller boxes.
DubNDodge Posted October 20, 2012 Author Report Posted October 20, 2012 AQ specs say 80 square inches of port at that net volume, a rather big box for a trunk, the DC Audio 12s can work in 1.5 cubes per sub. many other brands fit in smaller boxes. It's going to be forward firing sealed off from trunk. I know its needs 80 but dang.... Thats like 38-9ish hz. I love the lows, that's why I wanted to keep it around 32hz. Kranny made a good point that they have a stiff suspension and like big port areas. I'm assuming if I tune much higher I will loose all my lows, which would defeat the purpose of building this box. I understand too that if I tune to low I'll loose upper frequencies. Nothings going to get built yet. But I'd say once I piece everything together it should be within 1-2months. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Joe X Posted October 20, 2012 Report Posted October 20, 2012 If by any chance you haven't seen this before, you can tune lower a center ported box doing the following: Also you can set your port area to whatever you want as long as everything fits on the baffle.
Guest Posted October 20, 2012 Report Posted October 20, 2012 If by any chance you haven't seen this before, you can tune lower a center ported box doing the following: Also you can set your port area to whatever you want as long as everything fits on the baffle. once again you prove how you aren't good at box designs. why the FUCK would you tell someone that they can make the port area whatever they want? WHAT?! im sorry, but are you an idiot?
DubNDodge Posted October 21, 2012 Author Report Posted October 21, 2012 If by any chance you haven't seen this before, you can tune lower a center ported box doing the following: Also you can set your port area to whatever you want as long as everything fits on the baffle. once again you prove how you aren't good at box designs. why the FUCK would you tell someone that they can make the port area whatever they want? WHAT?! im sorry, but are you an idiot? Because I should move the fucking port '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
ccmotox99 Posted October 31, 2012 Report Posted October 31, 2012 Yeah so I kind figured it out on my own that the box would be choking out the subs... So sadly I am going to have to go with 2 12s" Here are some of my designs below. They will be flush mounted. I like the way the center port looks. I was also wonder would it harm or benefit putting mdf 3/4" rings right behind where the subs would be mounting, so it would have more support. Is there any need to put 45's anywhere? This is the side port, incase the center port isn't a good design. Torres for the box Where did you find this sub box calculator at? -playing with different setups
Guest Posted October 31, 2012 Report Posted October 31, 2012 sub calculator he used is in the enclosure section of the forum. named Torres Box Calc. its near the top of the enclosure section.
severancej Posted October 31, 2012 Report Posted October 31, 2012 If by any chance you haven't seen this before, you can tune lower a center ported box doing the following: Also you can set your port area to whatever you want as long as everything fits on the baffle. once again you prove how you aren't good at box designs. why the FUCK would you tell someone that they can make the port area whatever they want? WHAT?! im sorry, but are you an idiot? 98' dodge ram 140A alt Big 3 XS D2700 JVC kd-r310 Rockford T500-1BDCP 2 Sundown E12 Ported 4cubes 35hz Rockford P400-4 2 Infinity reference 3way 6x9 2 Polk DB 5 1/4 2x layer dynamat all doors
DubNDodge Posted November 7, 2012 Author Report Posted November 7, 2012 Now new plans. Just going to put 2 HDC3 12's in, instead of putting in sdc2.5s then upgrading later. Anyways these will be on 1k for now, then I will be putting them on 3k later. I was wondering if this box would be choking out the subs at all, they just seem to close to the side wall and port, but I have not experience with building boxes. Would this be a decent box for running them on 1k / 3k rms? '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
