when having a high output stereo in a car everything has voltage drop. if the headunit isnt getting the power it needs i would only assume the rca voltage would drop aswell.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
so in the end if you have a cd player with a 6 volt preout and a cd player with a 4 volt pre out and the amp can be set to 50volts with out clipping and has an internal gain of 10 volts the cd player with the 4 volt pre out would be able to allow you to push you equipment to its max with out clipping while the cd player with the 6 volt preout would create more clipping and only hurt the output and sound quality of the system.
I noticed this personaly on my own ride. I have Chrysler 300 with the stock HU that has a Rockford BLD (3Sixty Line Driver) for the added sub stage . My sub stage is a fully upgraded single 10" DC XL m2 running off a DC 2.0k. The line driver has 2 modes Balanced and Unbalanaced. In Balanced mode it produces 22 Vrms and 11 Vrms in Unbalanced mode. When setting my gains (line driver hace a gain as well) with the DD-1 , I noticed that in balanced mode I get full time distortion on 0db 40hz track. But in balanced mode I can addjust the gains slightly (if at all).
Also when I set the amp if I use the -5bdb track on Unbalanced mode I'll get full time distortion decteted on my DD-1.
The reason the BLD is 11 Vrms unbalanced and 22 Vrms balanced is because in unbalanced mode it puts up to 11 Vrms on the center pin of the RCA and grounds the shield. In "balanced" mode it puts 11 Vrms on the center pin of the RCA AND 11 Vrms on the shield!! If your amplifier doesn't have balanced or differential inputs, you are shorting the BLD out in balanced mode. Take a digial meter, set it to ohms, with the amplifier not turned on and the RCAs disconnected measure the resistance from battery ground connection to RCA shield. Let me know
CJ, you've Peaked my interest here.
Is It unreasonable to think there's head unit voltage drop?
AC voltage output X amplifier internal gain.
Scenario 1: .35VAC x 10
Scenario 2: 10VAC x .35
Assuming amplifier internal gain is a constant, voltage drop at the headunit is going to change which scenario more?
The RCA output voltage will not drop with B+ voltage dropping. The RCA outputs are fed from a mini-amplifier inside the headunit that has feedback. Think of it as regulated
Edited by TonyD'Amore
  • Like (+1 Rep) 2
With all of that being said, what would or could be the reason for a .5db increase in score? The TL doesnt lie.
All setting the same for both tests and amp tuned with dd1 with same track for both test.
6Vac input voltage- 155.71db
.33Vac input voltage- 156.17db
I don't know CJ, we are talking 0.46dB. If the voice coil temperature changed between runs you might see this. Can you get those results consistantly?
I may actually test this for myself tomorrow. I will hook up my 1.2k in my truck and just run wires to the sub in my explorer to see what happens. I am curious to see if I get the same results. I will make sure to give the sub plenty of time to cool down between runs.
Was going to say...
I'm gonna hate
Thank you Tony. I appreciate the feedback.
To expand on it, if possible, what makes the AC voltage output from the 'mini amplifier' in the head unit different from that of the AC voltage output of the amplifier in the back?
.46 DB increase, is a HUGE increase at that SPL level. Different voice coil temps, or whatever is not going to make a .5 db diff. Maybe in a Extreme vehicle.
Cody, Every amp has a sweet spot, A spot the gain likes to be. Also try messing with the phase if your just running 1 amp, or 2 amps strapped. If your running more than 2 amps strapped dont because you wont be able to achieve the same phase on each master amp.
  • Who's Online   1 Member, 0 Anonymous, 628 Guests (See full list)
