DC Power 370xp & 5.7 350 Vortec tension pulley problem
Is there a way to tighten the free moving tension pulley on this type of setup... my alt is slipping but belt is not sqeacking...it's a old belt which is going to get changed out for a gatorback & hopefully fixes it...but I was wondering if there is a way to tighten it a little ?
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
Change the belt, maybe even shorter if it still slips. How much surface contact do you have at the alt, belt to pully?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
This, did you put a new belt on when you put the alt on? Get a Gates Green Stripe belt.
there is no way to set the tension manually. how old is your tensioner? I just swapped mine out when i did my alts. its like 30 bucks for a new tensioner.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I think this is the best thing to do after talking to a few alternator shops...my tensioner is weak & I'll replace it with a new belt....thanks for info
MLA module 15+volts
Team Bass Hz
I'm going with a Gates green belt but that website is a little confusing for me...can anyone tell me which belt I should get from them...people say the green HD belt would be best but can't find the one I need.....I need the correct name of the belt since there is a few different types so I can order or get at O'reilly's if they have it.....
MLA module 15+volts
Team Bass Hz
the hds would require modification if i remember right. it needs ribs removed in order to work.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I got mine at napa and car quest.. Take number off of it then match up it's a hd belt or heavy duty
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
So I might have to cut some ribs off so it can fit correctly on pulleys...
MLA module 15+volts
Team Bass Hz
Which one is the better belt...Goodyear Gatorback or Gates green stripe...this is for one 370 DC Power alt so I dont think I need the all green HD Gates belt....I'm going to buy one or the other in the next 2 hours so your input is needed....I have used the Gatorback before so I know it's a good belt...me & a homie are going to install the Gates belt tensioner & a new belt @ 5pm so which one should I get
MLA module 15+volts
Team Bass Hz
  • Who's Online   0 Members, 0 Anonymous, 1042 Guests (See full list)
